Question about Dell Inspiron 2200 Notebook
Start>Run>now what? Usually under Start, if I select 'Run' a small rectangular box appears. It says Open:___ Then there is a white box. Every time I did this there was something already written in this box. I never noticed what it was. I would just push okay and a screen would appear that listed a bunch of programs (?) running. I'd scroll down till I saw 'wireless internet'. After selecting this a grey box appeared and said that my wireless was stopped. I'd then push a button saying 'start'. This would let my wireless internet work. After that I could get a list of networks and choose from there. I've been having problems fully connecting to my wireless (it always says acquiring address) so I've been fiddling around with stuff. Well, somehow, when I got to Start>Run, the box is blank. I don't know what was there and how to get it back. Now I can't even initiate my wireless. I am clueless here but trying. Thank you!
  • 2 more comments
  • therlihy209 Jan 26, 2009
    Thanks evo725
    I tried that and it brought me to a screen I've already been to, but not what I'm looking for.
    cpenzes:
    I see where you're coming from, and I understand all the other steps to get the wireless going, but for some reason I always had to do that, but it worked! I don't understand Run, or where it takes me, but it took me to a screen where wireless was listed and here it would say something about automatic wireless and show that it was stopped and allow me to start it up again. And after that, I'd do all those other things people have been telling me, and I could connect to the internet.
    My main question is, what was originally listed under Run, and can I get it back? Are most Dells set on something to begin with? After it disappeared I tried clicking that arrow and a blank white box appeared. My only option was to type in something random or click 'browse' and when i click browse, i have no idea what to look for.
    What is that function (Run) usually used for? My friend had showed me how I had to do that so I'm not sure if she typed something in the box that always stayed there. I had assumed it had already been there. It looked like one of those long complicated list of words and symbols (much like this comment ha)
    rtrahan:
    i've done what you explained, but the networks do not show up. when i click on my wireless option It says 'windows cannot configure this wireless connection'. There is no list of networks. BUT I am used to this, this is what always happens. I've been taught that in order to make it so that the networks are listed I have to go to Run, where i select wireless and start it. Ive done it this way on my computer for years and it's worked just fine for me.
    Thing is, whatever was listed on Run has disappeared so I cant do this mysterious step that no one seems familiar with.
    I have microsoft windows XP
    I FOUND IT!
    It was under Control Panel>Administrative Tools>Services
    This was the window I was looking for. No idea why going through RUN got me there. Thank you everyone for your help anyway!
  • 741 Answers
The run box can be used for several things like getting to DOS or running programs directly from it. Without knowing the name of your program I cannot tell you what was in the box. However, that is ok because that is normally how you start your wireless anyway. You did not mention what operating system you are using (vista vs xp) but it is almost the same process and if you get stuck just reply and it will come directly to me. Click on start>control panel>network connections then right-click on your wireless network connection and it will bring up a either a list of networks (some of those are your neighbors) or your network. Click on connect and you should connect immediately. Be aware that sometimes you will connect to other unsecure networks with a low signal if they are any available. That may be why you are getting a low connect rate. You need to check it each time to ensure it is yours that you are connecting to. Once connected you will see an icon in your lower right taskbar. You can click on that anytime to make sure you are connected to yours. If you have any questions let me know.
Don't forget to rate this solution before logging out.
Posted on Jan 26, 2009
    Genius:
  • Dell Master
  • 1,102 Answers
SHOULD NEVER NEED TO GOT TO START RUN to access your wireless
check control panel network connections if your connection shows right click if you see Enable click it
if you do not see enable then click REPAIR
let me know if this helped
last time you clicked run did you hit the arrow to see if it has just moved down
  • 1 more comment
  • DEKR
    DEKR Jan 26, 2009
    when you clicked on run did it take you to a page then you clicked startup
    important that i know
  • DEKR
    DEKR Jan 26, 2009
    I am glad you found it going to run and startup is'nt a good idea you can easily make a mess of your system
  • DEKR
    DEKR Feb 01, 2009
    could you please rate me
    Problem Solver:
  • 12 Answers
Another way to start up your wireless connection utility is to look in your system tray in the far bottom right corner of your screen.  You should see something like four bars like in the cell phone commercial.  Double click that, and you should get the same wireless connection utility up.
  • Eddie Vev Jan 26, 2009
    Type "taskmgr" without the quotes.  This is probably what you're looking for.
    Or actually, try typing "services.msc" If you want your wireless to stay on all the time, you can right click the wireless service and set it to start automatically.
HOW DO I OPEN THE DVD ON MY ACER ASPIRE E1-472P-6860 OPEN DVD DRIVE
On the DVD drive door there is a very small rectangular push button. It is about 5/32 inch wide by 3/8 inch long. it may take several several attempts at pushing the button but it should open the drive. If it does not open up the My Computer icon of your computer and left click on the DVD icon. When the drop down box appears select eject and right click on it. That should open your drive. I hope info this helps you.
Jun 28, 2014 | Acer Aspire 5610-4648 Notebook
Replaced brain box,but still wont start
the number on the pcm has to match and you will need to swap the eprom out from the old one to the new one. open the unit and you will see a rectangular eprom simply lift it out and make sure it gose back in the same direction usually a small white dot in one corner to indicate pin 1
Jun 04, 2013 | 2000 Dodge Neon
How can i scan multiple pages into one pdf with mx870
Forget all the old postings here. They are not reflective of the 2016 information.
FEB 15 2016 For Windows 10
1. Open the Canon IJ Network Scan Utility. (Came with your MX870) on your PC. Make sure it is ENABLED. (Look for icon in the right side of your tray and right click on it.)
2. Open Canon MP Navigator EX Came with your MX870) on your PC.
2a. Click Scan/Import Button at the top.
2b. Click Photos/Documents (Platen) button on right side.
3. Place the first page of your document on the platen. Close lid.
3a. Click the green Scan big rectangular button.
3b. Remove first page of the document, place the second page of the document on the platen, close lid.
3c. NOTE: This time, there will be a small rectangular box in the same large white box that has the small thumbnails of the page of your document that you have scanned. The small box will be labeled "Scan Complete." There will be a note that says, "Scan complete, to continue scanning load the next document and click "SCAN." There are two choices only. "Scan" and "Exit."
4. Repeat step 3 - 3c clicking on the "Scan" button in the Scan Complete box for each page of the document. When the last page is scanned and the thumbnail is in the white box with the rest of the multi-page document, click on the "Exit" button.
5. Use the Ctrl button and choose each of the thumbnails representing the pages of the document you want to save as one file. Be sure they have a yellow frame highlighting each thumbnail, as well as have a small check in the little box at the bottom left of each thumbnail.
6. At the bottom left of the MP Navigator EX window, click on the rectangular box that says, "Save as PDF file."
7. Your multi-page PDF file will be saved in the location you have specified in the settings.
If you need the drivers and software for this go to the:
Canon Support ' MX Series' PIXMA MX870 site here:
https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mx-series/pixma-mx870
Under: Drivers and Downloads, choose "Recommended Downloads" and get this driver and File Name: MX870 series MP Driver Ver.1.06 (Windows) 01/29/16 31.73 MB
Then under Drivers and Downloads, choose "Software" and get this software and File Name:
MP Navigator EX Ver. 3.15 (Windows 10/10 x64/8.1/8.1 x64/8/8 x64/7/7 x64/Vista/Vista64/XP/2000) 07/22/15 47.72 MB
scan-multiple-pages-into-one-pdf-mx870-bias4r3nvd0f3ezi5ng1xfxy-5-5.jpg The pics of the page and information are for reference....
Oct 17, 2012 | Canon PIXMA MX870 Wireless Office...
How do I send comments to people on facebook?
go onto their profile. There should be box under the part that says wall. Type your comment here and push enter. When ever you see other comments and want to also comment there should be a small rectangular box were you can type, leave your comment and push enter
May 02, 2011 | Facebook Computers & Internet
Text is too small and difficult for me to see
On the Start menu:
  • Select Control Panel
In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In the Display Properties dialog box:
  • Select the Appearance tab.
  • Select a Windows and buttons style from the list.
  • Select a Color scheme from the list.
  • Select a Font size from the list.
For more customization:
Under Windows and buttons:
  • Select Windows Classic style.
Under Color scheme:
Select the color scheme you want from the expanded list of options
To change individual desktop elements such as title bars, icons, menus, and scrollbars:
  • Select the Advanced button.
In the Advanced Appearance dialog box:
To choose the screen element you want to change:
  • Select it from the Item list.
To choose available size, color and font styles:
  • Select from the attribute lists.
When you are finished with selections:
  • Select OK twice to close the dialog boxes.
To close Control Panel:
  • Select the Close button.
Control Panel: Display: Appearance tab: Advanced button
Control Panel: Display: Appearance tab: Advanced Appearance dialog box
To open the Ease of Access Center, select:
  • Start.
  • Control Panel.
  • Ease of Access.
  • Ease of Access Center.
Under Explore all settings, select:
  • Make the computer easier to see.
Under See also, select:
Personalize appearance and sound effects
In Personalize appearance and sounds, select:
  • Display Settings.
  • Under Resolution:
  • Select a resolution between Low (screen elements appear bigger) and High (screen elements appear smaller).
  • Select OK.
Apr 19, 2011 | Computers & Internet
Subaru justy starter relay location
Under the hood, there should be a relay box. It will be located near the battery (usually) or on the driver side. It is usually a small black rectangular or square shaped box; lift the top, and look inside the top for the layout (diagram/map) of the relays. Here you will find where the starter relay is at.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Aug 30, 2010 | 1987 Subaru Justy
Trouble printing postcard
This might be because the printer you are using does not support the Post Card printing.
Though you can try the Universal Drivers.
To install the Universal Drivers, perform the steps given below.
It may depend on operating system to operating system(I am posting with XP)
On the Windows taskbar, click Start , click Run , type control printers in the Open: box, and then press Enter . The Printers and Faxes window appears.
Under Printer Tasks on the left, click Add a printer . The Add Printer Wizard appears.
Click Next .
Select Local printer attached to this computer, and be sure the box under this selection is not checked.
Select USB001 for the printer port, and then click Next . The Install Printer Software dialog box appears.
Under Manufacturer , click HP , under Printers , click hp deskjet 990c , and then click Next . The Name Your Printer dialog box appears.
Use the default printer name, click No next to Do you want to use this printer as the default printer? , and then click Next .
Click Do not share this printer , and then click Next .
Click Finish to complete the setup.
Jun 02, 2010 | HP Photosmart D7360 All-In-One InkJet...
Code 10 cd/dvd
Lets follow this:-
1. Choose Start > Run..
2. Type regedit in the Open text box and click OK.
3. Expand my computer - Expand HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4.On the right hand side, you'll find upper and lower filters, select them one by one and delete.
5.Restart PC and hope it works for you.
Note:Create a restore point before you delete any key from registry.
Thanks
Oct 07, 2009 | Computers & Internet
Synchronize
Plug in player, which computer will then recognize.
Open WMP10 and then click the SYNC tab.
Click RECENTLY ADDED along the left column - your desired book(s) should be among those items to appear.
Upper right, in the small, square box for devices, your player should appear as the transfer location.
Now, physically drag the book(s) across to the right, and drop the item(s) along the right where it says "drag items here" [vertical rectangular box].
Click START SYNC at the bottom of that very box to send all of those books to the player.
When WMP says 100% complete you should have your playable (items)!
Aug 05, 2009 | SanDisk Sansa m240 MP3 Player
Monitor problem
Odd. The manual doesn't mention anything about that. It almost sounds like one or more control buttons is partially shorted or leaky. That can happen if a foreign substance got in it or it was stored in an unheated garage or shed for a long time, etc.
Jan 20, 2007 | IBM ThinkVision L170 17" LCD Monitor
Dell Inspiron 2200 Notebook Logo
82 people viewed this question
Alun Cox
