Question about Kenwood KDC-4024 CD Player
Some parts missing in KDC-4024
My Kenwood 4024V stops to play. I found C56 and C58 is missing after opening it. There are black "heap" in place of parts there. Please, what is the right values of these parts? Thanks
    President:
  • 3,130 Answers
Go here:http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69 or go to their support page located at the same site. Good Luck
Posted on Jul 15, 2007
SOURCE:
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Cd error on my kenwood kdc-4024
Try pressing reset button, if that dont work your optic is faulty. cheaper to buy new cd player.
Nov 03, 2009 | Kenwood KDC-4024 CD Player
Got a Kenwood KDC-PSW9524. For some reason the
MINE DID A SIMILAR THING THE FACE PLATE IS MOTORIZED AND GOT STUCK CLOSED SO INSTEAD OF BREAKING IT I FOUND THE RESET BUTTON ON THE RADIO IN THE FRONT ON THE SIDE ITS A LITTLE TINY BLACK HOLE STICK SAFETY PIN OR SOMETHING IN IT.BUT BE CAREFUL IF YOU DONT KNOW YOUR RADIOS SECURITY CODE IF NOT SURE WHILE STILL ON GO INTO THE OPTIONS AND TURN THE CODE ACCESS OFF.!
Apr 12, 2009 | Kenwood KDC-PSW9524 CD Player
Face wont open
if you have already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Dec 16, 2008 | Kenwood KDC-MP528 CD Player
I need a new removable front unit for my KDC-4024 were can I purchase one from and at what cost?
They dont sell them as a secutity measure, otherwise the theif that stole the unit out of a car could just buy a new front plate. You could try ebay, but i think kenwoods are coded to the units. Kenwood will replace units if you have purchase paperwork but you can get a 4024 for about £30 on ebay.
Apr 20, 2008 | Car Audio & Video
Kenwood kdc-x859 just stopped working
This hapened to me also. I removed the power fuse to the radio and it reset itself.
This solved the problem for me.
Feb 28, 2008 | Kenwood KDC-X859 CD Player
My KDC-X659 STOPPED PLAYING!
Hi Jeka65,
I think you need to have at least 11 volts or more on the yellow and the REd wires for it to turn on. Using a volt meter set on DC volts and at least a range of 20Volts, you can read the REd wire to the Black wire and see if you have at least 11 volts. Do the same for the yellow wire and reference to the black wire. you need at least 11 volts, Your car should be running about 13.6 volts across the battery.
Nov 22, 2007 | Kenwood KDC-X659 CD Player
Kenwood KDC-X590 ipod
Do you have a Ipod shuffle?
Is the deck on random?/shuffle?
Try pressing the small reset button on the deck, its small a small black button you would need a pencil tip to reset!
Hope it helps,
Don
Mar 16, 2007 | Kenwood KDC-X590 CD Player
Kenwood KDC-715s problem.
the kenwoods with the motorized face platesdevelop one problem with time. the flexable ribbon cable between the main unit & the face plate. as the face open & closes, over time wares out the cable. problem consists of face plate not opening/closing, display missing & and/or some or all buttons not working. note these can also be intermittent problems. typically the part number is located on the cable itself on the side where it pluggs into the main board. since you have a service manual, you should verify it in the manual. good luck.
Dec 03, 2006 | Kenwood KDC-715S
Don't play any music
Is there an orange "dimmer" wire missing? I found out the hard way,
using and older harness, that it needed an additional power wire.
If I remember correctly, it goes in directly under the ground wire,
in the next row.
Hope I helped
Wendy
Sep 27, 2006 | Kenwood KDC-V6017 CD Player
Kenwood KDC-4024 CD Player Logo
101 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
