Question about Miele WT 2780 Front Load Washer
Drying never stops
When dry to wardrobe selected it shows 0.10 hours and works forever.
How long does concrete take to dry?
it will be dry enough to touch after 24 hours. chemically speaking, it continually dries and becomes harder forever
Jan 15, 2013 | Building Materials
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Jan 07, 2013 | Dryers
My drier was on the sensor cycle and was supposed to run for 54 mins. It was still drying over 2 hours later and the display showed there were 42 mins remaining in the cycle. The clothes were completely...
More than likely the temperature sensor has gone bad. If the unit is under warranty I would contact the dealer...otherwise you need to replace the sensor.
Sep 01, 2011 | Samsung 7.3 Cu. Ft. Super Capacity...
Turned on Dryer today; problem; Estimated time remaining window shows CL (no time) Non of the time buttons selected show time in window. Dryer runs forever; gets hot and drys clothes. Pause button does...
The Child Lock feature is activated and it can be deactivated by pressing and holding the DRY LEVEL button for 3 seconds or until the CL display is cleared.
Indicate the exact model number of the dryer if the control panel doesn't look like the one shown above or if no button with the small "PRESS & HOLD 3 SEC TO SET CHILD LOCK" (DRY LEVEL) marking is found.
Mar 06, 2011 | LG DLE2514 Electric Dryer
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Automatic Dry Function Has Stopped Working
There is a humidity sensor which acts as an auto cutoff switch in most driers, as your load auto dries , it senses the change in humidty and kicks the power off. It is often shaped like a flying saucer with wire terminals on the wings. That is likely your culprit, generally located close to the element. Based on your description, I would start there. Also test a load on timed dry, but it sounds like that's your problem. Remember to unplug before looking under the hood. Post back if you need further info
Sep 20, 2009 | Dryers
Dryer stops working after 2 minutes into cycle
If it is new, is it not under warranty?
does it run ok on air dry? Is there good air flow?
post your answers in comments
May 14, 2017 | Whirlpool WED9500T Electric Dryer
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Miele WT 2780 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
