SOURCE: my candy civ60 dryer dose not heat
hi i too had that problem,when an engineer looked at it the thermostat,element were ok,he suggested that there was a blockage in the air flow,i took the whole thing apart ( i had nothing to lose ) cleaned it with a hoover very carefully then with a clean dry paintbrush,there is vents underneath the dryer if these get blocked the dryer blows cold air, its a saftey measure so that the fluff dosent catch fire ! i hope this helps,mine has run ok for 3 months now.
SOURCE: tumble dryer Creda Smplicity T320VW
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at [email protected] if you still need help.
SOURCE: creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
