Question about Acer Aspire 5600 Series 5630-6951 Laptop
Laptop overheaying and shutting down every 5 minutes
It is on a hard flat surface but it keeps over heating. the fan rounds very very loud as soon as you turn it on.
I had the same problem. It was solved when i sent the notebook to acer assistance. They simply applied more thermal grease, because when assembling the notebook processor, they only use the thermal grease sent with the processor out of the box, wich i was told, was not enough.
And after that, a friend of mine told me I should try using a protocol called undervolting. I whould only recomend it if you have some knowledge because it takes a lot to configure your notebook to undervolt the processor.
The fact is that after i sent my notebook to the tech assistance it never overheated again even before i had it undervolted.
Hope i was helpfull.
Posted on Jan 29, 2009
  • 15,935 Answers
The fan bushing is worn. There should be no sound from the fan whatsoever, and it should only kick on under extreme workloads.
Replace the fan soon, as if you repeatedly run the processor hot, you may encounter further damage.
Thank you for using FixYa - A FixYa rating is appreciated!!
Posted on Jan 26, 2009
I bought a lenovo g580 laptop, and the computer shuts down after 30 minutes of use. The temperature is around 45~50 degrees which isn't that huge.
Sounds like temperature or maybe a faulty battery. Are you using the laptop on a hard flat surface? Need to in order for the system fan to keep everything cool. Also , are the vents free of dust and debris?
Sep 29, 2013 | Lenovo G580 Laptop
My laptop is over heating
Hi! first, i would like to ask if you are using cooling fan? if does, then i'll give you some tips on how to keep your laptop from overheating
1. Turn off your computer and allow it cool down.
2. Work with your laptop on a flat surface. The rubber feet on your laptop are designed to allow airflow to the underside of the computer, so if you are working on a bed or other soft surface, you cut off the airflow. If you do want to work away from a desk or table, try keeping your computer on your lap, exposing the underside to air.
3.Shut down your laptop before placing it in your carrying bag.
4 Give your laptop a bit more lift to increase the airflow under the machine. Two simple, flat rulers placed along the front and back edges of your computer is enough to increase the flow of air and keep your laptop cool.
5 .Unplug your charger as soon as the battery is full. A common mistake people make is leaving their computer plugged in at all times. However, the constant source of electricity will heat your battery and in turn overheat your laptop. Only charge your computer as long as necessary.
Hope this would be helpful.
Thanks for usinf FixYa : )
Sep 13, 2011 | Dell Computers & Internet
My loptop keeps restarting every 5 minuts
If you are notusing your laptop on a flat surface, it may be obstructing the cooling vents onthe bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust. A laptop fanassisted cooling pad may solve your problem
May 20, 2011 | Toshiba Computers & Internet
Hi this is Martina, my Sony Vaio laptop shuts off by itself without warning. Sometimes it's after 2 minutes of being online or 5 or 20 minutes. The battery is charged and it also does it when its plugged...
Could be over heating, make sure you are using your laptop on a hard flat surface. If you smother the fans underneath , temperature inside will rise and cause it to shut down. Also verify that the fans are working when you turn it on, see if you can feel them pushing air out, or if you can hear them.
Nov 16, 2010 | Computers & Internet
My acer extensa 4420-5963 gets really hot and shuts down. also, my battery seems to lose and gain charge within a few minutes. And norton's report says the laptop is running on low memory. help! please
It could all be down to the heat problem.
Check the fan housing, is it clear of dust. If not there is usually lies the problem.
When using the latop, ensure its on a flat surface so the air can circulate around the vents and fans.
Mar 14, 2010 | Computers & Internet
My medion laptop keeps overheating
change your laptop heat sink fan
Nov 11, 2009 | Computers & Internet
My laptop an Acer Aspire 5610z shuts dow every 5 minutes. The fan is running VERY loud and the bottom of the computer gets very hot. I am using it on a flat hard surface so I have no idea why it is doing...
if your acer is like mine it gets very hot and a thermal curout switch shuts down the item, to prevent damage to cpu.
i raised mine, and put a cooling pad unit under it, which the 3 fans driven by a usb plug continually cool it, i also moved into a cool room with good air circulation.
Jan 26, 2009 | Acer Aspire 5610-4648 Notebook
Aspire 5100
Hi Fayez,
How soon does the laptop switch off? Immediately, or a few minutes into booting into Windows, or ... ?
It could be an overheating issue. If you're using it on your lap or on a soft surface such as a couch or bed, the fan might not be able to release the heat.
Try putting something underneath the back of the laptop and place it on a stable surface such as a desk and boot it up - see if it still shuts down.
Otherwise, let me know how soon it's switching off, or at what point if it's the same point every time.
Ben
Mar 07, 2008 | Acer Aspire 5100-5033 Notebook
Help my laptop keeps shutting down
seems like it mioght have the blue screen of death. go to google, and search for a program called "Bart PE" download this program, run it and let it burn to a CD. Now, boot the laptop from this CD, and let it load. Now click on go, and find the command prompt. type in "CHKDSK C:/r" and let it run. once it finishes,l reboot and take the CD out. Now your laptop should work perfectly. Best of luck dude ;)
Feb 28, 2008 | HP Pavilion dv6000z Notebook
My Acer 5630 laptop turns off automatically
Alongside cleaning out the fan, try use your laptop on a hard surface, not your lap! Don't put anything like a pillow underneath. Use it on a flat hard surface and the heat has chance to escape!
Jan 11, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
