Question about Barco RLM-W6 DLP Projector With Lens
Error and red light show
At first open projector then ok but remote power on or error that my problem.
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
My projector it not working! i press the power button and it green light but it not light show can you please help me and also colour keep flashing.
Sounds like the lamp might have blown. Sometimes the projector can't tell if the lamp is blown, so the usual red indicator light doesn't show.
After the projector is on, if you push menu on the remote do you see anything? Maybe the brightness is just turned down all the way. If you see no menu when you push the menu button it's time to inspect the lamp.
Open up the projector and pull out the lamp. You'll probably need a screwdriver to remove the cover, and then another screwdriver to unscrew the lamp and pull it out. Be careful not to touch the bulb's insides. Is the lamp on the inside of the fixture bulbous, or cracked. Look closely.
Mar 28, 2011 | Optoma EP721 Projector
Can't reset lamp timer for new bulb
when you replace old lamp with new one the lamp timer not reset automatically the counter is a software data and you reset manually with remote control
HOW :Connect the power cord to the projector. The ON/STANDBY indicator light in red
Use remote control and press the following key on the remote control in following order for less than five second each.
RESET +LEFT ARROW KEY+ RIGHT ARROW KEY+ENTER (as show in picture)
Feb 10, 2011 | Sony VPL-ES2 Multimedia Projector
Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Dec 12, 2009 | BenQ PB8220 Multimedia Projector
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 27, 2008 | NEC VT47 Multimedia Projector
Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
Oct 23, 2007 | NEC VT47 Multimedia Projector
Barco RLM-W6 DLP Projector With Lens Logo
23 people viewed this question
Top Barco Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Barco Office Equipment and Supply Expert? Answer questions, earn points and help others
