Faulty LG 37lc55 LG 37" LCD
This screen is usable but after about 10 mins the screen starts to flicker then switches off, give it about 10 mins and it will work again, does any 1 have any ideas? could this be bad caps? or power supply over heating ?
  • 83 Answers
SOURCE: Power supply unit, TV cuts off after 20 seconds
i would recommend ebay, they usually have lots of parts for lcd tvs
Posted on Jan 25, 2009
  • 92 Answers
SOURCE: LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Posted on Mar 28, 2009
  • 157 Answers
SOURCE: Philips LCD TV 37PF5520D/10. TV will not switch on.
philips has a problem with bad caps(swollen)in power supply-try shopjimmys.com enter model number-scroll down til you find power supply-order it simple to put in.if they do not have it write down part number then google it to find one--you also can change the bad caps yuorself if you are handy with a soldering iron
Posted on Sep 11, 2009
nostechjb
  • 28 Answers
SOURCE: LG LCD flickers and turns itself off
I'm guessing here.. most probably its the ccfl tubes..
Posted on Nov 15, 2009
  • 458 Answers
SOURCE: 3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Posted on Dec 19, 2009
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
Lg 37lc7d is having trouble turning on, it starts then stops, then starts and stops then turns on after a couple of mins what is happening
- Flickering screen
- Dim screen
- Slow start
May 26, 2014 | Televison & Video
LG 32LC2DB television says No Signal after 30 min
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | LG Televison & Video
Laptop screen suddenly starts flickering with warious color bars
If your lcd screen got harizotal line ( Pink, blue or red ) and flickering, that means your lcd ribbon or board on back top was crack or faulty I believe your lcd screen model is LG Display. There are not have any way to repair it. You must be replace with another lcd but I suggest you to change it with Samsung brand lcd screen. You can buy new lcd screen from ebay.com
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jul 20, 2011 | Toshiba Computers & Internet
Hi i have a 42" LG lcd tv .When i switch it on
the inverter for the backlight likely has a bad capacitor or more. The fluctuating high voltage is causing the jumping and eventual blackness until sufficient charge is on the caps, at which point it stabilizes...it eventually will stay black unless the caps are replaced.
Mar 05, 2011 | LG 42LC2D 42 in. LCD HDTV
Flickering screen
Two models of the 46 inch Sony Bravia have a screen flicker problem. On my 2008 model, starting from cold, it lasts for 5-10 min, on LHS of screen. The Telefix tech who visited said this is common with these models (46in only), a new panel is needed. Sony provides warranty on this fault for 3 yrs, so you do not need extended warranty to claim. Discuss your case with Sony or Telefix.
Jan 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
The screen is cracked and not usable (LG Viewty KU990)
You can replace the screen yourself and get it back up and running. 20 dollars for the lcd screen and 15 for the touchscreen from ebay.
Check out the following link for a guide and video on it and links to buy the screens.
Replace Cracked LG Viewty LCD Screen
Dec 30, 2009 | LG KU990 Viewty
I hope this helps.
Mar 28, 2009 | Televison & Video
LG L1900E flickering after cold start
This is probably due to a bad solder joint somewhere. Bad solder joints can effect a unit in the reverse also. IE works at first and then dies after it gets warm. Think about how metal expands when it is heated. And contracts as it gets cold. If there is a hairline fracture on one or more component joints, this would cause it to not have such a great or solid connection when it is cool, or contracted. As it gets warmer, the solder expands therefore filling the void and giving it a good connection.
Regardless, it will likely only get worse over time. If you're handy with a soldering iron, pop it open and reflow all the joints. Especially the ones on the transformers and copper coils. Best to hit them all, excluding the tiny surface mount devices.
If you need further help or if you'd like to have this, or any other LCD monitor repaired for a flat rate fee of $40, please visit my web site http://BoiseLCD.webs.com, or email me at cjmclellen@msn.com.
BOISE LCD - LCD Monitor Repair
Chris McLellen
(208) 891-9117
cjmclellen@msn.com
Dec 29, 2008 | LG Computers & Internet
Flickering monitor
this problem many caused by bad inverter. If invertes not function, it won't feed back a good signal to tell mainboard that LCD backlight is working, so the mainboard turn off the display.
To fix this problem, it is need a qualify technician and inverter's part.
Send it to LG, they will not charge you expensive. LG have a great service.
May this help.
Oct 09, 2008 | LG Flatron L1750S 17" LCD Monitor
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
