It didnot gives me windows startup display when usually i starts it for the first time,it took several attempts by restarting the whole systyem,i am running windows seven premimum addition with 1 gb ram,problem remains the same as i have changed the windows periodically after two or three months,can you please help me to get rid of this issue.thanks regards usman
  • 7,627 Answers
Unplug, remove battery, plug in, reboot. Any change? I'm not sure I fully understand your statement. "i have changed the windows periodically after two or three months,"?
Posted on Jan 19, 2013
ChipcircuiT
  • 157 Answers
SOURCE: Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
Posted on Jan 05, 2009
fossildude
  • 832 Answers
SOURCE: lenovo startup problem
hi thanks for using fixya!
I suggest if you can try to make a windows update for your system. Then try to make a disk defragment. And try to conduct a full scan of your anti-virus. Then observe your system, if all same problem, I suggest that you format your system.
If you need further assistance, let me know. regards!
Posted on Apr 26, 2009
Geekman
  • 32281 Answers
SOURCE: Dell inspiron 6400 start up problem.
Can you hear the hard drive spinning and the computer appears to be running but you you get a blank screen. If you look at the LCD screen at an acute angle and you see a dim image. then you have a backlight problem. To determine if you have a video card problem or a lcd screen problem, Connect an external monitor to your laptop and power the monitor up first and then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Get back to me with the results of these tests and any error messages etc. so I can advise you.
Posted on Jun 19, 2009
ta_mcguire
  • 125 Answers
SOURCE: eee pc won't start
sounds like a registry error try to start in safe mode if it does the same thing then when it starts to boot and says xp and the bar starts to move hold down the on off button till it goes off and let it set for a bit (let the hard drive stop turning) and reboot should send it into chkdisk whick will correct the registry error
Posted on Jul 15, 2009
joegoldman
  • 335 Answers
SOURCE: Acer 3680 needs several days rest before restarting.
Hi George,
If you power on with an external monitor connected, no function-F5 is necessary - it will default to the external monitor automatically.
I don't think Darkman is on the right path here (sorry Darkman). It is possible, but I suspect not. A damaged/corrupt page file won't fix itself automatically after 5-7 days and suddenly boot the PC.....honestly. If there are bad sectors on the hard drive though, this could certainly be the issue. We'll get to this in a bit....
We need to eliminate a few potential problems first.....like sketchy hardware.
Please remove the ram and clean the contacts on it, and the slot(s) with a pink pencil eraser. You want to make the contacts clean and shiny. The ram chips are under an access panel on the bottom of the laptop. Try to boot. If no good, read on.
Please try removing the hard drive drive from the laptop (see below). Try booting with no hd first. If you see an Acer splash screen (logo), and then 'no operating system found', then the hard drive is likely the issue:
If it boots consistently with no hard drive, then please try this:
Enter the bios of the laptop by pressing either F2 or del at boot time when you see the Acer logo. Go to 'boot' options, and make sure the optical drive is the first boot device at the top of the list. From here, you need to get a Windows XP cd (yes, I know you're running vista). Put the hard drive back in, boot the laptop to the cd and select the option to repair windows from the recovery console. Once you have a command/dos prompt, type the following:
chkdsk c: /r
This command will check the hard drive for file corruption and bad sectors. This will take 1-3 hrs probably, depending on the size of the hard drive. If it indicates that data was recovered from bad sectors, and the laptop boots now, shut it down, take it to a reputable repair shop immediately and ask them to clone your hard drive onto a new one. Bad sectors = impending doom.
If it won't boot with the hard drive removed....try removing the optical (dvd) drive. If still no joy with hd and optical removed, let me know.
You can access the hard drive from an access panel on the bottom of the laptop. Remove the cover, remove any retaining screws for the hard drive and simply slide it to disengage the connector and pop it out. If still no boot, one screw on the bottom of the laptop will release the optical drive. Flip the laptop over, and try to visualize where the optical drive sits in the laptop. The screw will be near one of the corners of where the optical drive drive sits.
Please let me know how you make out. Don't worry... I will help you ascertain the cause of the issue :)
Posted on Aug 23, 2009
Testimonial: "Brilliant. Will try this tomorrow and get back you. Many many thanks. Adrian."
Disable safe mode
Which operating system and do you have Norton antivirus ???
Turn Off Safe Mode
You rebooted your PC at least 10 times now, and still it refuses to start in anything other than Safe Mode.
Your many attempts to perform a system restore have yet to be victorious. It just will not boot up normally.
According to Microsoft, if you have Norton Antivirus 2001 installed on your computer, it is the root of the problem. Microsoft suggests you disable it.
Restart your computer. Let it load completely in Safe Mode.
Press "Run" on your Start menu.
Once you see the Open box, enter into the provided text box: misconfig.
Then press "Enter" or Select "OK."
Select on the new dialog box that has appeared "Selective Startup."
Select "NAVAP.VxD" on the Static VxD tab.
Remove the check in the check box you now see.
Select "OK."
Remove the check in the check box next to Norton Auto Protect.
Select "OK."
Reboot your system and it will be in Normal Mode.
Turn Off Safe Mode in Windows XP
The purpose of booting your computer in safe mode is to resolve issues.
Only your basic, most dire drivers and programs will run to block viruses and surreptitious software from executing on your system.
But once the issue is resolved, you need to get back to the standard Windows mode. In order to turn off safe mode in Windows XP, you must go through the same steps that you took to turn it on.
Reboot your Windows system.
Press the "F8" key several times as soon as you see the first Windows XP logo appear on your screen as the computer is booting.
This will bring up a black screen that displays the "Windows Advanced Options Menu."
Press the down arrow button on your keyboard to scroll down the list.
Select "Start Windows Normally" and then hit "Enter."
Allow the system to boot.
Enter your Windows XP user password (if you set one) and log in as usual.
Nov 14, 2013 | Computers & Internet
My pc with windows 7 ultimate got stuck on the startup. usually, when you start the pc, "starting windows and windows icon" appear and after that, welcome and your desktop. but in my case, ONLY the...
Back up all data and re-image the computer. You can either use a windows 7 disk or create a bootable usb. there is likly a problem with the boot manager.
Sep 22, 2013 | Microsoft Windows 7 Ultimate for PC
Schedule record application starts automatically in background when system restats
Try this:
Disabling Startup Programs in Windows For some programs, it's smart to have them start with Windows, such as anti-virus and firewall software. However, for most programs, starting them at boot-up just wastes resources and extends startup time. There is a tool installed with Windows, called MSConfig, that allows you to quickly and easily see what's running at startup and disable the programs you prefer to run on our own after startup as needed. This tool is available and can be used to disable startup programs in Windows 7, Vista, and XP.
NOTE: MSConfig can be used to configure several things other than just startup programs, so be careful what you do with it. If you're not sure about using it, just follow the steps in this article and you should be fine.
To run MSConfig, open the Start menu and type "msconfig.exe" (without the quotes) in the Search box. As you type, results display. When you see "msconfig.exe," click on it or press Enter, if it is highlighted.
NOTE: If you are using Windows XP, open the Run dialog box from the Start menu, type "msconfig.exe" in the Open edit box, and click OK.
Click the Startup tab on the System Configuration main window. A list of all the startup programs displays with a check box next to each one. To prevent a program from starting up with Windows, select the check box next to the desired program so there is NO check mark in the box. Click OK once you have made your choices.
A dialog box displays telling you that you may need to restart your computer for the changes to take affect. Click Restart to restart your computer immediately. If are not ready to restart your computer, click Exit without restart.
Aug 26, 2012 | IBM Lenovo ThinkPad L412 Notebook
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    Can this be fixed??
    Your windows is corrupted You need to reinstall operating system.By repair or reformatiing hard disk through windows xp installation disk
    Jul 01, 2009 | Dell Inspiron B120 Notebook
    Lenovo Y510 stuck on logo screen at startup
    back up your data and do the fresh installation of OS
    Jun 13, 2009 | Lenovo ThinkPad T61 Notebook
    Windows cannot find 'gphone.exe'
    Gphone.exe is worm which spreads via instant messengers. It usually affects Yahoo! Messenger and Google Talk applications. Gphone.exe send a message and invites victims to visit a website. If clicked upon, the link actually delivers a copy of Gphone.exe infection.
    Most likely you have a security program that detected and removed the threat but windows is still trying to load the file on startup, thankfully it isnt able to because the threat is gone so windows is displaying that error message to let you know it was not able to load the file.
    Go to Start > Run> type "msconfig" and press enter. click the startup tab and uncheck the box that says "gphone.exe". (it may have a long file or folder path in front like c:windowssystem32).
    Go to this website if you need further removal instructions:
    http://www.spywarevoid.com/remove-gphoneexe-gphoneexe-worm-removal.html
    Jan 21, 2009 | Computers & Internet
    Computers & Internet Logo
    16 people viewed this question
    David Payne
    David Payne
