Question about Whirlpool Duet GHW9150P Front Load Washer
Door leaks the spring came out and i'm not sure how to replace it
  • 5,911 Answers
If the outer door spring came loose, the following link will explain how to reinsert it:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
The link explains the entire procedure for replacing the door bellow (rubber boot). Read line item 12 for instructions on how to reinsert the outer spring.
What can cause this spring to come loose is over stuffing the drum to the point where items are getting caught in the door boot and pulling. I don't know if this is your situation, but offered the advice just in case. The salesperson will often advertise that these washers can be packed FULL. "The larger the load, the better", I have often heard. While the washer DOES perform better when more items are in the drum, resist the urge to over load.
If you have questions, please let me know. I hope this helps you.
Posted on Jan 27, 2009
I am trying to install a new heat motor on a frigidaire refrigerator model frs26zrg. I am having frost build up on front side of ice maker, assuming its from flapper not closing all the way.
I assume your frost is at the front of the ice bin? If so, your correct. Room temperature air is leaking in to a 0 degree environment and causing frost build up. First, I would see if the ice door closes 100% without spring by pressing your finger on the door. I've had bad ice doors that were warped. Next, inspect supporting rod and spring and make sure they look ok. An eye test should suffice. Next, without heat motor, the spring should keep door shut 100%. See if that helps, good luck!
Sep 18, 2015 | Frigidaire Refrigerators
Fisher/p nemo dishwasher door
it is sometimes linked to the dishwasher not level or the spring tension on one side getting weak. Refer installation manual http://kitchen.manualsonline.com/mdownloads/c11d2c17-cb0a-489c-99bf-a61513fbf876.pdf to make sure the level is adjusted. May need to replace the door seal in case leak is too excessive.
Apr 27, 2013 | Fisher and Paykel Dishwashers
The rubber gasket around the drum opening is leaking and rusting
You can replace it by lifting the lip of the rubber around the edge and finding the wire where the springs connect there you can stretch the springs apart, remove the wire and pull off the rubber. Just make sure first that is where the leak is, sometimes a leak in the soap dispenser water tube can seem like door gasket leak.
May 16, 2011 | LG WM2277H Front Load Washer
I have water leak out of our front loader, it leaks out rite in the middle from the bottom of the door. I am not sure if it is from the small hole in the door or if it because of a bad seal. The rubber...
the wire ring just keeps the seal in place,, make sure the bottom of the door glass is clean,, if so look at the seal and see if it is pushed in alittle around the bottom,,you can take a hair dryer and heat it up while pulling it back out ,, ( just the lip part) if that doesnt work you will need to replace the whole gasket
Jan 24, 2011 | LG WM-2277HW Front Load Washer
I replaced the door gasket on my bosch 3200 washer and it leaks water when finished
If oit has only started to leak since you changed the door gasket, then it suggests to me that it is not fitted correctly.
make sure you have the inner retaining spring or clamp securely fastened .
Jan 11, 2010 | Bosch Washing Machines
The door won't close.
replace the door lock assy, you can't fix this without almost certainly breaking it by prying with a flat screwdriver. Remove door boot spring, fold door boot back over door lock area, unscrew door lock screws (3), then remove from harnesses and replace. Reverse door boot and spring removal, top of spring first, then work your way down ensuring a good snug fit with no water leaks, it may take you a couple of trys.
Jul 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Leaking under dishwasher
replace the door seal thank you for usein fixya rate me
May 17, 2009 | Dishwashers
MAYTAG MDBO880AWB LEAKS FROM LEFT SIDE DOOR ONLY SOMETIMES AND
If the door is sprung in a manner that one side is flush and not other then most likely the hinge has been bent outward by the weight placed on it.the best solution would be to replace hinge,the spring only adjusts the tension for door closing. There is a slight possibility that either the frame or the door has bent in this manner so before buying hinge check frame and door for damage,after doing repair would suggest adjusting front legs of unit to raise front up a bit to ensure leaking wont continue
Apr 21, 2009 | Dishwashers
Washing machine wm1814cw
Check the wire ring that goes around the rubber seal located just inside the door - we had to call a repair person out one day because our door was leaking, and he told us it's important that the spring be at the top of the door opening to prevent leaks from happening. He had a hard time moving the spring to the top but that seemed to help.
A few months later we found a water leak from our soap tray, so we had the tray replaced under warranty, although I'm not sure that helped because the replacement looked identical to the old one. It only leaked when we used powdered Oxyclean and liquid soap in the tray at the same time; the leaking water ran behind the front cover and dripped out onto the floor all along the front of the machine, mostly near the left corner, but we stopped putting Oxyclean into the tray & the problem stopped. Hope that helps.
Feb 05, 2008 | LG WM1814CW Front Load Washer
Maytag frontload washer door is leaking
Yes you can do it. the door boot has come off the tub opening. first you will have to push on the door boot (gray rubber)on. There is a grove that slides into the metal opening in the washer. make sure the the door boot (gray rubber)lays flat against the outer opening. then with the spring at the bottom . start at the top put the wire in the rubber grove. until you get the the spring then pull down on the spring and tuck it into the grove.. I hope this helped [lease let me know if you get it... krazytech
Sep 13, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
