Question about Viking D3 RDSCE2305BSS 30" Freestanding Electric Range with 5 Surface Elements, 4.7 cu. ft. Vari-Speed Dual Flow Convection Oven, Self-Clean, TruGlide Full Extension Racks and 6" Backguard Included: Stainless Steel
Oven light won't turn off on Viking D3 - Viking D3 RDSCE2305BSS 30" Freestanding Electric Range with 5 Surface Elements, 4.7 cu. ft. Vari-Speed Dual Flow Convection Oven, Self-Clean, TruGlide Full Extension Racks and 6" Backguard Included: Stainless Steel
Is there a specific regulator for a Viking D3 cooktop or can I purchase one off the shelf?
If it runs on natural gas it has a lower pressure regulator than one that runs on propane gas. Nat gas is 1.1kpa propane is 2.75kpa
May 03, 2014 | Viking D3 RDGSU2605B 36" Gas Cooktop with...
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
Oven door won't open after self cleaning cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 13, 2011 | Viking 27" Professional Select Built-in...
Viking oven gets warm but not real hot. The coil does not get red and appears to be not working
Typically the problem is with the oven controller. IF your RTD (resistive temperature device) is ok then your oven controller board is faulty. When the oven is turned on (bake mode) the oven controller closes the relay that controls the bottom element and the oven begins to heat. The RTD or thermostat provides a feedback loop to the oven controller. RTDs don't partially fail, they either work or they don't. Since your oven is getting warm I would imagine the RTD is okay. You can verify the RTD by measuring its resistance at room temperature. Remove power from the oven and either remove the RTD completely and measure with an OHM meter or remove leads and measure while still attached to the oven chassis. You may have to remove it if your ohm meter leads won't reach. I don't know your model oven but most RTDs at room temp are about 1.1 kohms or 1100 ohms. If this is the case your RTD is fine and your controller board is bad. Please let me know if you need anything else. Good luck!
Jul 02, 2011 | Viking Kitchen Ranges
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Viking D3 RDSCE2305BSS 30" Freestanding Electric Range with 5 Surface Elements, 4.7 cu. ft. Vari-Speed Dual Flow Convection Oven, Self-Clean, TruGlide Full Extension Racks and 6" Backguard Included: Stainless Steel Logo
119 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
