Question about GE Dryers
Maytag Epic Dryer - Motor Relay on Control Board burnt? Dryer will power up with all lights on front working. Press start button and it just clicks then nothing. We pulled out the control board and saw the little burnt spot around the connection in back of where the motor relay is on the board. My question is - this board is at the least $200. Can we/should we just replace the motor relay or just try to resodder the existing. Also - should we be concerned as to what made it blow? This is a model MED9800TQ0 dryer.
4 Suggested Answers
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
  • 91 Answers
SOURCE: my dryer wont start
possible belt broken
Posted on Jan 04, 2009
SOURCE: Dryer has power, dim control leds, will not run most of the time.
Same problem here. I replaced the machine control electronics p/n 8546219 and got 12 months service out of it before it returned to what you are describing above. I even replaced all the LED's on the board and that did not do a thing. I can tell you that this will be the last whirlpool appliance that will ever enter my home. Simply overpriced garbage!
Posted on Jan 03, 2011
Control board sparks, smokes and smells when trying to start
Did you have a lightning strike near by? Or power outage with a power surge. Could have shorted the board.
Mar 13, 2015 | Maytag Epic MGD9700S 27 7.3 cuft. Gas...
Maytag epic z power button wont start machine
Maytag dryer. has no start check door switch. if not door switch then its your relay board that may be bad also check all stats.
there will be 2 at blower cage and 2 on heater assembly
The 2 on blower cage one of these are a resister stat has to be exact resistance or dryer wont start or will start and then shut off dryer b4 it is completed drying hope this helps there should be a cheat sheet paper work that will help you diagnose your problem fallow the steps if not with dryer can be viewed online
Jun 25, 2014 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic dryer
Without seeing dryer and checking it , best guess could be main control board problem
Dec 08, 2013 | Dryers
Dryer only runs while holding start button in
We have a Maytag Epic dryer with the same problem (Model MED9800TQ0). Pulled out the control board yesterday and saw that the weld had been blown right at the motor relay (burnt marks surrounding the area on the flip side of the board where the relay attaches). Do you suggest we replace the motor relay or just try to re-soder that part on the board? Also - should we be concerned as to how this happened (that it was something elsewhere that caused it to blow)?
Jan 16, 2013 | GE Dryers
My new Epic Z is only one month old
sounds to me like there is a short in the wiring or control board i would call the warranty company to come fix it
Dec 30, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic dryer won't start
hi there,
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
Dec 17, 2008 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Dryer
you have a main control board failure , motor relay burnt out ,,,
Nov 20, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
55 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
