Question about Philips CD445 Cordless Phone
I have no ringtone
When I have an incoming call there is no ringtone, I have had this phone for over 2 years and never had a problem. It is displaying that it's not on mute and the battery is charged.
On the SAMSUNG SGH-ZV40 how can i change the ring tones. can i get a step by step guide as my screen has broken
Hi Lilfranza,
Menu structure is: Menu/Settings/Profiles/Normal Profile/Options/Incoming Call/Voice Call Ringtone see details below
Sound Settings
You can customize various sound settings.
1. When the Idle screen displays, press the Menu soft key.
2. Select Settings and press the Select soft key or the Cingular icon key.
3. Select Profiles and press the Select soft key or the Cingular icon key. Use the Down
Navigation key to scroll through the following list of available options:
Normal Profile
To access the available options for this calling profile, press the Options soft key.
Highlight Edit and press the Select soft key or the Cingular icon key. Use the Left and Right
Navigation keys to move between the various tabs. This menu allows you to alter the
audio settings for the following categories:
• Incoming Call: allows you to edit the properties for audio alert used for incoming
phone calls.
-_ Voice Call Ringtone: allows you to select a ringtone from your My Stuff (Phone)
folder which contains not only the default phone ringtones, but also any new
ringtones which have been downloaded from the Internet.
Mar 15, 2011 | Samsung SGH-ZV40 Cellular Phone
Dear sirs. I hope you can help. I just got the droid HTC EVO. i somehow installed a music video that plays and displays whenever I get a phonecall with this terrible clip of some musician. I desperately...
here are two ways to setup a ringtone for incoming calls.
  1. From the Home screen tap Settings > Sound & display > Phone ringtone. Tap the ring tone you want to use on the list, and then tap OK.
  2. You can also use a music file as a ringtone. To set up a music file as your ringtone, please use the micro USB cable to connect the phone to a USB port on your computer. The Connect to PC dialog box displays and prompts you to choose Disk drive > Done. Your phone's SD card is mounted as a drive on your computer. You can now copy music files to the SD card.
After you have finished copying, open the notifications panel (by touching and then dragging the status bar down) on your device; then in the Notifications panel, touch Charge only.
Then tap All programs > Music > tap the music you want to set as a ringtone (the music will start playing) > press Menu > Set as ringtone. You can set the music file as a Phone ringtone or Contact ringtone or you can select Trim the ringtone.
Jan 16, 2011 | HTC EVO 4G Smartphone
I need different ringtones on my Nortel 7310
you should already, intrnal is double ring and external is long single ring. you can set sounds from the softkeys below display.
Nov 12, 2009 | Lands Phones
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Incoming ringtone problem
see your local service provider store, they can help you more than we can.
Aug 24, 2009 | O2 Samsung SGH-E250 Cellular Phone
Cant put a ringtones as a incoming text message
there is a way aroung this just go to oficial mod site www.lg-vu.com search me my name is "tierrize"
May 11, 2009 | LG Vu CU920 Cellular Phone
Incoming messages alert tones
first of all open menu of your phone then tap on setup(the one with screw driver on it) icon to open it then select ring alert style and select your alert style you will see a bottun bellow displaying "EDIT" tap on it then a menu will apear with volume level, Ringtone line 1, Ringtone line 2, Massage tone....
you can edit all of them by taping on the folder type icon flashing in front of them......!!!!!
I think it will help you...if not then reply me at ik1788@gmail.com
Feb 02, 2009 | Motorola Mobility MING A1200
No ringtone on Katana phone
Sure the phone is not in sient mode.Is loud speaker working. if not change N2150 ringer IC or get it changed with a technician.
Nov 19, 2008 | Nokia 1110i Cellular Phone
My nokia n95 8gb doesnt display some incoming callers names?
Call ID must be activated in your phone. Your cell phone provider customer service must help you with that.
Artgirl
Jul 20, 2008 | Nokia N95 Cellular Phone
Incoming calls
Try to reset the unit with the phone again.
Feb 25, 2007 | Motorola Mobility H500 Wireless Headset
Philips CD445 Cordless Phone Logo
29 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
