Hard drive totaly reformated
E recovery wiped out
  • 7,627 Answers
OK, what is your question? Contact your Computer Manufacturer's website for a Factory Recovery Disk. Buy a Windows Install DVD. If you don't have one and reinstall the OS.
Posted on Jan 19, 2013
4 Suggested Answers
harvester3
  • 181 Answers
SOURCE: installing drivers after reformating hard drive
Well, can you use the system you wrote this post on to access Toshiba's support site, download the drivers for the M35, and tranfer them via flash drive or cd or usb? That would be best, given the information at hand. You don't have to use the actual system in question to download drivers. Good luck
Posted on Oct 08, 2007
  • 111 Answers
SOURCE: reformating the hard drive
just simply use a ordinary XP cd installer and you will have an option to delete all partitions and reformat the HDD (not quickformat). But normally errors like what you got there is caused by Bad cd or cd drive.
Hope this helps.
Posted on Apr 19, 2008
  • 305 Answers
SOURCE: 0xa0000002 acer aspire 5315 recovery after new
make sure disc is clean wash gently with warm soapy water going from middle to outer edge then dry with soft cloth going from middle to outer edge make sure cdrom is set to boot first then put RECOVERY DISC in first when finished put system disc in.
hope this helps.
Posted on Apr 28, 2010
Reformatting the hard drive
if you have a spare cd lying around, one way is to download HBCD
which contains several utilities for reformating hard drives.
http://www.hirensbootcd.org/download/
I recomend using the dos program option, and selecting hard drive tools, and your manufacturers tool. select write to zeros, and that will completely wipe the drive to its raw state.
May 25, 2012 | Dell Dimension 3000 PC Desktop
I was wiping the hard drive when the laptop
Please come back to us with the exact error if you get any.
However, how you are performing recovery. Using recovery manager or recovery discs?
If you are using recovery manager, please perform hard drive self test and check with the result.
Hard drive self test steps:
1. Turn Off the notebook.
2. Turn ON the notebook and keep tapping F10 key
3. Once you are in BIOS, navigate to tools/diagnostics tab with the help of left and right arrow key.
4. You will find Primary HDD self test or HDD self test.
5. With the help of up and down arrow key select the respective test and hit enter.
6. Short test will take only 4-5 minutes. However, long test may take 40-60 minutes.
If the hard drive is fine, try to perform recovery using recovery discs....
If still the problem exists try with different discs.
If the hard drive fails replace the hard drive.
Hope this will work for you!!!!!!!!!!!!!!!111
Mar 17, 2010 | HP Compaq Presario V2000 Notebook
How do you wipe the compaq presario m2000
I'm not sure if you are wiping it to start over or to sell/give away.
Many newer machines have a Recovery Partition, usually your "D:" drive.
Access the System Recovery partition from the Start-All Programs-System Recovery-System Recovery Menu. Following the prompts will allow you to reformat the computer and reinstall the operating system and all software as it came from the factory. From that point, if you don't want any of the factory junk, you'll need to uninstall it yourself.
If the Recovery partition is missing, (usually a D: drive) , then you'll need to have the original Recovery discs which were created when the computer was new.
If you simply want to wipe it, use a disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads.com to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
Read more: http://pcs.suite101.com/article.cfm/wiping_your_computer_hard_drvie#ixzz0RZDlV3Qr
Sep 19, 2009 | Compaq Presario M2000 Notebook
Reformated used HP recovery disc when I restart it says SW build ID different from ID on recovery media
You have 2 options. You can write to Microsoft or to HP about your Issue & they might be able to help about the ID issue. Best I would suggest you buy the OS. ( Full installation Pack) this way you have nothing to worry.
May 11, 2009 | HP Pavilion a1610n PC Desktop
I need to recover data from an external hard drive
Use Kernel for FAT Plus NTFS v4.03 for Data Recovery, until u made changes in ur HDD u will easily recovery your files..
- Rajkumar
Nov 25, 2008 | Interactive Media Kanguru QuickSilver 60...
Needs reformated
Most probably you will have to format the disk ... since the partion might have lost from the .. thumb drive..
so use some kind of recovery tools to get the data bak from your drive ...
there is a lot of recovery tools in Hiren's Boot Cd ...
Nov 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hey did you ever get your playstation fixed from saying hard disk corrupted if so can you please tell me
Yes, it is fixable. The hard drive can be wiped clean then reformated on your PS3. But I just replace the Hard Drives on units that do that and sell the bad one. Hope this helps. Good luck to you!
Jul 22, 2008 | Sony Playstation 3 (PS3) Console
Vista 64bit
You can't. The only way is the hard way - reinstall and wipe the disk. Sen your thanks to Bill Gates....
Jul 17, 2008 | Microsoft Windows Vista Ultimate Edition
Reformating the hard drive
high level format should appear as an option from recovery cd..
Apr 19, 2008 | Toshiba Satellite A45-S150 Notebook
Reformating my hard drive
Several ways to do it. If you have the XP CD, you should be able to boot to it. Delete the partition and then choose to "Format the partition using the NTFS file system."
Remember to backup any data before you start. It will wipe your drive clean.
Nov 26, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
