Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
Hi, I am looking for a USB cable for WD Hard Drive WD2500I032-001, can you help?
Yes should be the same as a high quality printer cable
belkin
http://www.amazon.com/Mediabridge-Hi-Speed-USB-2-0-Cable/dp/B001MXLD4G/ref=sr_1_3?ie=UTF8&qid=1360070240&sr=8-3&keywords=usb+printer+cable
Hi, I am looking for a USB cable for WD Hard Drive - 2_5_2013_1_20_49_pm.jpg
Posted on Feb 05, 2013
3 Suggested Answers
Suricatta
  • 92 Answers
SOURCE: WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Posted on Jun 24, 2009
SOURCE: My PC is not recognizing my WD Passport 120GB USB external drive.
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Posted on Mar 08, 2009
My PS3 wont recognise my WD Elements 500GB hard drive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 27, 2011 | Western Digital WD Elements Portable...
Hi,my WD Elements Desktop WDBAAU0015HBK hard drive is not showing on computer.how to solve?plz help me...
hope this helps
Jun 23, 2011 | Western Digital WD Elements Desktop...
My WD 500 GB portable Hard disk is not showing on my computer. Till yesterday it was ok and would show up as soon as i plugged in the usb hub. I tried going to devise management but could find the hard...
depending on a few things
do you hear the drive powering up? like the platters inside are spinning? if so you know that the power to the hard drive is working and the data may be the problem you would want to try new usb cables if those do not work then it would probably be a bad usb port on the hard drive
if you don't hear the platters inside the hard drive spinning up when you plug it in then it sounds like the power is bad on the hard drive or the hard drives cables i would try a new cable first and then if that does not work try contacting WD about a warranty on your hard drive here is a link to WD support page for warranty
hope this helps
Mar 05, 2011 | Western Digital WD Passport 250GB Portable...
My computer can no longer recognize my WDBAAU0015HBK, western digital portable hardrive. I have tried everything swapping computers, USB cable, etc. All I want now is to return this hardrive (RMA) to WD...
DID YOU TRY GOING TO ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, UNDER STORAGE CLICK DISK MANAGEMENT, ENLARGE THE PAGE , LOOK FOR YOUR DRIVE, RIGHT CLICK YOUR DRIVE AND MARK PARTITION AS ACTIVE. ....HOPE THIS HELPS.......JEFFXC
Feb 08, 2011 | Western Digital WD Elements Desktop...
Computer not recognising hard drive. I have even looked in disk management and it's not recognised there either. The hard drive is lighting up when connected so it is working.
HI sineadkirk1
There are several reasons why your hard disk can not be recognised by the computer
1> usb cable problem
2> usb port problem
3> the problem on a computer virus or hard disk
4> computer problem
5> hard disk problem
do the test one by one to ensure that the root cause
thanks&regards
Jan 09, 2011 | Western Digital Elements powered by WD 320...
Hi I have maxtor 1TB external hard drive, not used it for over six month, now when I connect it, nothing happens, my laptop doesn't recognise or even sense/acknowledge it's existence!! Can you help?
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, at a significant discount.
Nov 04, 2010 | Western Digital My Book Essential Edition...
Wont recognize usb anymore
if the external hard disk drive powers on, perhaps replacing the USB cable could help ?
i had WD extrenal, and it crapped out on me -- i had so much vital information that i lost . i finally discovered that the power modeul inside the housing that encases the drive was bad.. i coul not get the PC board replaced.
i hope you can resolve this with new USB cable.
have you tried another computer -- see if that PC recognises the WD external drive
let me know how it works out for you
Nov 03, 2010 | Western Digital WD Passport 250GB Portable...
Hi, my WD hard drive is connected to my macbook, but can't access
check under the system profiler which can be found in the applications folder and then in the utilities folder. See if under usb whether the drive is showing under there. If it is, open up disk utility and use the verify disk to see if there is a problem with the drive, if there is use the repair disk to repair it.
Other things to check try a different usb port on the macbook or a different usb cable.
Hope this helps
Oct 21, 2009 | Western Digital 250GB MyBook External USB...
Laptop suddenly stopped recognising my external USB hard drive
I had the same exact problem with a WD2500xms passport. The problem was the USB cable. I went to the store and bought a 6' USB cable ( $26 at Radio Shack) with the same specs and now, no more problems. Also I called WD technical support (800.275.4932) and asked for a new cable. The WD customer serverice was very helpful and said it would sending me a new cable for free. When it arrives I'll return the 6'er.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
128 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
