Question about Dell (6U214) Motherboard
6U214 Motherboard Failure??
Hi, I have a dell dimension 4550 with a 6U214 motherboard. I flashed the bios when I was having other issues and now when I go into setup, I see my hard drives are showing "Unknown Device".
What can I do to get it to recognize the hard drives again. Thanks in advance for your help.
    Problem Solver:
  • 9 Answers
1. try clearing your bios setup using the jumper provided on your motherboard. make sure that the computer is shutdown and power cable unplugged before doing this. make the jumper settings and wait for 3 to 5 minutes before returning the jumper settings back to its normal position.to locate the bios clear jumper; it's always near the cmos battery of the mainboard. after doing so, plug back your power cable and power "on" your computer. select bios or cmos default settings when you are prompted. save your settings and restart your computer.
or
2. or try flashing your motherboard again using the latest bios file available for your board downloaded from dell website. and select to bios or cmos default settings when you are prompted. save your settings and restart your computer.
Posted on Apr 09, 2010
Reset System BIOS Dell Dimension 4550
go to vendor website (DELL), support drivers and software and from there download BIOS upgrades and then reflash your BIOS...
WARNING:
meddling with bios for amateurs is not recomended ! You must download and flash the right BIOS that is from your machine !
Mar 07, 2014 | Dell Dimension 4550 PC Desktop
Can i put a amd processors in a dell dimension
Short answer: NO.
Long answer: AMD processors have a different pin-arrangement than found on a Socket 478 motherboard, so they physically will not fit.
Jul 03, 2010 | Dell Dimension 4550 P4 Socket 478B...
Led with number 9 displayed is flashing
LED 9 flashing can mean many things. Here is the list of "flashing codes" for the vostro 1510.
Keep in mind a flashing led is going to blink 3 times. for example,
number one would look like this:
On (solid lit). Blink, blink,blink (paused off) blink, blink, blink... (paused off), (then repeat)
1. ON-FLASH-FLASH = No Ram or ram not seen
2. ON-FLASH-ON = Ram has a problem
3. FLASH-FLASH-FLASH = Motherboard failure (replace board)
4. FLASH-ON-ON = CPU Fault/failure
5. FLASH-ON-FLASH = LCD detect failure/fault
6. ON-ON-FLASH = MINI pci card (controller) failure/fault
7. FLASH-FLASH-OFF = Keyboard fault/failure
8. FLASH-OFF-FLASH = USB FAILURE
9. FLASH-FLASH-ON = Video BIOS or BIOS issue
10. ON-FLASH-FLASH = Modem issue
Depending on the blinking code, you might just need to re-seat or replace your RAM or your CPU. But then again, you could have a more severe motherboard issue.
Nov 01, 2009 | Dell Vostro 1510 Motherboard System Board...
My Dell Dimension 4550 won't recognize my CPU.
your problem is the same as trying to put a AMD3 into a AMD2 socket, yes it fits and yes i physically should be able to run it it but in reality it won't
Sep 26, 2009 | Dell Dimension 4550 P4 Socket 478B...
J9H2 connector on dell 4550
here's a few links to hopefully help you in your struggle cause i own a dell (which i'm using right now) as well and have occasional issues too:
http://answers.yahoo.com/question/index?qid=20081105033803AAYVSaL
http://74.125.95.132/search?q=cache:h2BG70gROrMJ:support.dell.com/support/edocs/systems/dim4550/D0995bk0.pdf+what+are+the+pins+for+on+a+J9H2+connector+on+dell+4550%3F&cd=3&hl=en&ct=clnk&gl=us
http://stason.org/TULARC/pc/motherboards/A/AST-RESEARCH-INC-Pentium-ADVANTAGE-612-221475-F01.html
I hope these help, if you need any more help, contact my email:
romlovespuddingpops@hotmail.com.
Jun 25, 2009 | Dell Dimension 4550 PC Desktop
Dimension 4550 CN 02U819 power supply works but
many dells take proprietary power supplies. if you are using an aftermarket power supply, then you may have burned out your mobo. irregardless, your mobo may be dead, and that mey be the very problem.
Jun 08, 2009 | Dell (E210882) Motherboard
Primary hard drive not found
since you already tried removing and reseating the hdds . The problem could be the motherbaord slot. To troubleshoot the same
1. First Disconnect all hardrives and optical drives from the system
2. Go to the system setup or BIOS
  1. Turn on (or restart) your computer.
  2. When the blue DELL™ logo appears, press <F2> immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again.
3. Hold down the ALT key and press "F"
4. Hit ESC , save changes and exit .
5. SHutdown the system
6. Reconnect the HDD IDE cable to the optical drive connector on the motherboard.
You can refer to the following motherboard diagram
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101668
7. Check if the hdd , is getting detected in the system setup
You can refer to the following link on how to read system setup screen
http://support.dell.com/support/edocs/systems/dim4550/syssetup.htm
Thanks
Proton
Jan 30, 2009 | Dell Dimension 4550 P4 Socket 478B...
Dell dimensio 4550
you need to replace your motherboard. contact vendor
Dec 15, 2008 | Dell Dimension 4550 PC Desktop
Computers & Internet Logo
121 people viewed this question
Alun Cox
