After a out 6 months the image in my Vizio E370VL is too big for my screen. I've gone through the screen settings which is currently set for HD. I was wrong in the bideo. Even when I choose Normal the
    Problem Solver:
  • 4 Answers
ARE YOU ON CABLE AND USING A CABLE BOX? IF SO, ON MOST CABLE REMOTES THEY HAVE ON THE RIGHT SIDE A ZOOM BUTTON . THE PCITURE CHANGES EVERY TIME YOU PRESS THE BUTTON -KEEP PRESSING AND RELEASING THE BUTTON UNTIL
YOU HAVE A NORMAL PICTURE.
Posted on Jan 20, 2013
jscruggs420
  • 36 Answers
SOURCE: VIZIO BLACK SCREEN
That problem is the Ysus board, Sometimes people will replace the Zboard at the same time. If you bought it at costco a couple of years ago you are in luck costco will refund your purchase price, costco has changed the return policy and newer tv's are not refunded, but something to look into
Posted on Jan 17, 2009
SOURCE: I have a vizio vw32L40a and the screen is too
6/09 I had the same problem when receiving the signal over the air with the input set to TV. Perhaps the signal strength or type was varying. At any rate, after I hooked up HD cable and watch from that input, the problem no longer occurs.
Posted on Jun 27, 2009
Axle80
  • 73 Answers
SOURCE: vizio p42 type sp42a nov 2004 hd tv
The sp42a is a plasma tv not an lcd. check the psb voltages first then move onto the ymain and buffers.
Posted on Aug 25, 2009
SOURCE: Aquos Screen Image Too Big.
I had the same problem, but it looked like my son pressed the view mode button on the remote. I set it back to Dot by Dot and it looks perfect again. Try it out.
Posted on Sep 09, 2009
budmrtn
  • 11361 Answers
SOURCE: vizio 320m. I set it up wrong. Instead of choosing
You should be able to use the input/source function on your remote to select which signal sources you want the TV to display, find out which input on the TV you have the cable box hook it up to then just select that input. Do you still have the user manual?
Posted on Oct 31, 2009
Vizio VO370M red color has gone away
Change the input to some other device and see. Then if the problem persists, this might need attention by a qualified service technician.
Jul 25, 2012 | Vizio E370VL 37 in. LCD HDTV
37 in vizio tv stays on vizio screen
Main system memory IC might have been damaged. Set need service Contact any experienced service technician; or the authorised service center for Vizio at your town.
May 12, 2012 | Vizio E370VL 37 in. LCD HDTV
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
Vizio e370vl turns on then powers off
This unit has infra red detector for remote. You may be getting IR from another source in the room (eg: bad light bulb or light reflecting off window pane). Also if you use the JAG Wheel on side of set, instead try the remote - the JAG Wheel may be the problem (dirty switch or damaged).
Oct 04, 2011 | Vizio E370VL 37 in. LCD HDTV
I have color vertical lines instead of a picture on the screen
color vertical lines means the lcd PANEL is gone bad. it is a costly part which can cost more then 70% of the total cost. you need to replace it.
Sep 26, 2011 | Vizio E370VL 37 in. LCD HDTV
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
Busted screen on a vizio e370vl is it fixable
I wasnt able to locate the panel part number. There were 2 different ones used in your set based on the serial number. But I have never ever seen a panel that was cheaper than the purchase price of a new tv. I hate giving out bad news.. Sorry Most places that sell salvage parts for tv's like ShopJimmy.com never have the LCD screens because thats what always is broken making them salvage..
Oct 19, 2010 | Vizio L37 Television
Vizio GV42LHDTV - No video inputs
my 42 also went black, and the "vizio" logo in front indicates as if it is turned on, it clicks on and off, but just has no output on the screen, meaning not a black screen, just a dead, no image, even when the system has clicked on
I tried turning off, on, unplugging, letting it sit (kind of like a reboot wishful thinking), removed all connections in back, (nothing still, not even the blue screen) just nothing.
What a shame, I had the unit less than 6 months, and now this? I have work to do, and I can't get it done.
Feb 25, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
