Question about Compaq Presario S4020WM PC Desktop
Black screen While trying to download a new XP windows operating system on a Compaq Presario S4020WM,,,the pc froze,,,so it was restarted. Now there is nothing but a black screen. We tried another drive,another cd rom,new memory,another monitor,another power supply...the screen is still solid black,,,,there is no flashing cursor. Do I need to go into the bios and change something. If so,how and what. THANKS for any help.
  • reynoldsbill Jan 26, 2009
    The fan is definitely running. The cords are good,,hopefully I'll get it to work with another monitor,,it's worth a try. If not maybe it is the CPU.....THANKS,I do appreciate the help.
    Problem Solver:
  • 12 Answers
My next step would be to see if there is a CPU fan and find out if it is spinning.  The problem sounds like a bad CPU, which is usually caused by a bad fan.
Are there any beeps when you try to start it?  If the answer is yes, then it is probably a bad video card or motherboard.
If there are no beeps, spinning fans, or lights turning on, it could be a problem with power.  You changed the power supply, so the next thing to check would be the cables all the way from the wall to the motherboard.  You also should verify that the power switch that is actually built onto the power supply is set to on before you try the other power switch on the front of the computer.
Posted on Jan 26, 2009
  • Eddie Vev Jan 26, 2009
    Try hitting F8 repeatedly about once a second immediately after rebooting.  If the problem is a video driver, then you should get a menu that pops up where one of the options is "safe mode."  If you select that, you should be able to finish loading Windows, and then update the video driver.
  • 741 Answers
Ensure that the power button is pressed and the monitor is plugged in correctly. If ok, then the installation was stopped while installing your video drivers. If possible use another monitor to re-load the xp operating system until completed. Once the video monitor drivers are loaded the monitor will work again. Let me know if you have any questions.
Don't forget to rate this solution before you log off.
  • Randall  Trahan
    Randall Trahan Jan 26, 2009
    Please rate the solutions before you log off.
I have a S4020WM. I installed a new video card. The computer was running slow and my Start Menu task bar was missing. I rebooted the computer and ran in safe mode. I shut down the computer. The next time I...
i cant understrand how you got to VGA card
PC ran great before but not after card stuffed in
nor if PC had a card before, then changed it a different card
Some PC have VGA chip on board and need no card. for VGA.
onboard fails, or it and the existing card fails the add 2nd card and it fails.... there is story here you never told.
The OS is corrupted.
reload, XP.
XP is a virus magnet, id up graded it.
but if you love danger.
there is only 2 ways to restore.
1: the F10./F11 restore key
I first carbon date pC, ,after age matters, things go obsolete fast.
so. how old is the beast. real name.
Compaq Presario S4020WM this pc is 100% RETIRED< zero support by HP
https://support.hp.com/us-en/retired-products
i found, that it does have onboard VGA 15pin jack
center of read MOBO.
so do both fail>???????????????????????????
try some install disks to reinstall the os
try F8, yes, F8 dead, means the OS is corrupted
needs OS reInstalled, for sure.
buy the disks from HP or 3rd party
Mar 22, 2017 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Compaq C700 keeps freezing.
You, more than likely have a VIRUS.. Try these two programs to check and remove them..
1) Malwarebytes Malware Removal http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
2) kaspersky virus removal tool.**Choose the tool at the bottom of the list..
http://support.kaspersky.com/viruses/utility
Run full Scans with BOTH OF THESE PROGRAMS. After they have completed, Run Windows CHKDSK /F /R from the Run Command Line in the Start Menu. This will fix any Operating System Issues created by the Virus. GOOD LUCK!!
Jul 15, 2010 | HP Compaq Presario CQ61410US Notebook
Have compaq presario f730us installed new screen and hard drive used hp restore disk to restore operating system.was working fine but fan kept cycling on and off ,and screen froze up.Shut down computer by...
There are three options you have.
  1. First of all you should undo changes as restore point if these problem were not earlier.
  2. Secondly, you should download and install combo fix utility to resolve all your issues. This utility is very useful.
  3. 3rd and last option is you should reinstall your operating system and reinstallation of your softwares and drivers also.
I hope you can resolve your problems if you are a provessional or know the computer well.
Good Luck
Dec 05, 2009 | HP Compaq Presario F500 F700 and G6000...
You need all the supported motherboard drivers (eg: PCI Bridge...) as you can see by the image of my Device manager screen there are MANY motherboard driver.621c9d7.jpg Goto manufacturers web site... You should be able to get them.
Apr 04, 2009 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
Start Normally (black screen with options)keeps re-loading itself
If you can't get into windows normally or into safe mode to try to restore the system back to a date when it worked properly then you'll need to wipe out the hard drive and start the system from scratch.
Feb 08, 2009 | Compaq Presario SR1050NX (DW257A) PC...
No desktop or anything else appears upon start up
format the pc & try loding the operating system gain......................................Sameearyan
Dec 15, 2008 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Audio driver
Compaq Presario 700 PC Notebook's main problem is audio driver for win xp.
For Audio driver software you can visit a link by just
Click Here .
For any other problems with this Notebook you can
Click Here .
Nov 09, 2008 | Compaq Presario 700 470024-192 Notebook
System will not load, keeps restarting ,will not go into safe mode
it may be cycling, when the system reboots, press and hold the power button, to completely switch off, then turn back on as normal
Aug 17, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario S4020WM PC Desktop Logo
89 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
