Forgotten password I have forgotten the password for my sitecom WLR 4000 vL 001 router. Resetting to default and using admin (user) and blank, password or admin (password) does not work.
  • 7,627 Answers
You can find a user manual here: http://www.sitecom.com/support/
Posted on Jan 19, 2013
  • 6 Answers
SOURCE: Reset Password
please post the model name of the router
Posted on Aug 23, 2007
insomniac
  • 103 Answers
SOURCE: Dell Wireless 2350 Router
Connect one of the router's LAN ports to the computer, no other connections to the router.
Reset the router to factory defaults by holding the reset for 15 seconds with power on.
Reboot the computer.
Start, Run, cmd /k ipconfig
The address of the Default Gateway is the base address of the router, type that into IE to access the setup pages.
Posted on Feb 22, 2008
peglegcards
  • 89 Answers
SOURCE: Default username for 5461 maxg
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
Posted on Mar 27, 2008
SOURCE: DI-624 can't login as admin
I was ready to give it up and pitch the thing, but I found this on another board and it worked:
login - admin
password - password (not blank)
Posted on Jun 08, 2009
  • 96 Answers
SOURCE: D-Link 615 Default password not working.
Your default admin password should also be blank.
-Comp Doctor
Posted on Feb 01, 2010
Adress is 192.168.1.254 iwhant ueser and password
type in a browser your IP address (192.168.1.254) a window should pop up asking for your credentials, Unless you have changed them they should be:
user: admin
password: (blank)
this is the default password for this router. If you have changed it (and forgotten it) , you can do a reset using a paper clip on the back of the unit. Note it will reset all settings back to the default setting.
Oct 04, 2011 | D-Link AirPlus DI-524 Wireless Router
I forget my password and my user name
By default, the password is "admin" without quotes. Leave the username field blank.
If that does not work, you may have to resort to resetting it back to default settings. Do this by finding a paperclip or pin, and pressing the reset button in the back.
May 27, 2011 | Linksys Wireless-G WRT54G Router
I forgot the password and username,and i want to change the security password of my router what shall i do?
If you have forgotten the router's password then you have to reset the router to factory default to access the interface again. Then you can use the router's default user name and password, that is admin and admin (or username: " " (leave it blank) and password: admin (all in lower case)
You can find the default passwords on the following website;
http://www.routerpasswords.com/index.asp
Once you have logged in to the router console, you can set new security password
Apr 01, 2011 | Linksys WRH54G Wireless Router
How to change Sitecom password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on wireless then wireless security Enable WEP then enter new password save settings and restart router .Then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Nov 17, 2010 | Computers & Internet
I forgot my user name and logon domain
If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port on the Router to restore the Router to factory settings.
After resetting the Router to factory defaults, use the default name and password.
Router Login: http://192.168.1.1
Login Name: admin
Login Password: password
Jul 02, 2010 | NetGear WNR2000 Wireless Router
Do not know username and password.
You will need to reset the router - stick a pin in the back where the reset button is and hold it in there for 10+ seconds while power is on. This will set it to the default for that model router - you can check Linksys site for the manual to get the default username and password.
May 10, 2010 | Linksys Wireless-G Broadband Router
I bought a ruiter sitecom to make a wireless
ou need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
May 07, 2010 | Computers & Internet
Lost my key password for belkin g router
there is a small reset button that u will need to push with a pen. Its usually to the back or side of the router.
Just jeep pushing it until the router resets then use the default username and password.
defaults. (normally)
user name - admin
password - admin
username - Admin
password - admin
username Admin
password Admin
user name Admin
password (blank)
username admin
password blank
look in your manual for the default username and password and instructions on how to reset.
Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Will not let me into router. only have an option for password and nothing works. tried resetting to default and it still doesnt work
are you trying to access the router set up ?
First make sure that your computer will be connected to the router with the ethernet cable.
Now check the IP address and Default gateway on the computer. Default gateway will be the IP address of the router.
When you try to access the router it will always ask you for the password.
Try the default user name = admin and password = admin
or try user name = blank ( do not type anything), password = admin.
if that is not working then the password of the router must be changed.
try some different password that you use most often.
If that doesn't work then you will need to reset the router and reconfigure the router.
once you reset the router , you will loose all the settings on the router.
Reset the router for 30 seconds. unplug the power. plug it back in. wait for 1 minute and try to open the page again.
Click Here to know more about how to reconfigure the router
Nov 17, 2009 | D-Link GamerLounge DGL-4300 Router...
Don't know the username to "http://192.168.0.1" router Level One.
If you have never changed this from default then the user name will be "admin" & the password will be "password" or "admin. If you google the default password for Your router model then that shoud find it if this does not work. Don't forget to rate me if this works for you.
Jul 06, 2009 | Levelone CP Technologies LevelOne FBR-4000...
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
