Question about Saniflo & Saniplus& Macerator Pump
How do i take lid off sanifo toilet cistern - Saniflo & Saniplus& Macerator Pump
  • 41 Answers
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Posted on Feb 07, 2013
How to mend a running gural vitrifiye toilet cistern
With lid removed, look down into it and remove and replace the black rubber thing in the center. This is the flush valve and is worn to the point where is no longer provides a tight seal allowing water to pass and run into bowl. Also, could be something underneath it not allowing it to seat properly.
Aug 26, 2014 | Home
Grohe service
toilet will need syphon replacing. the lid should lift of the cistern, some have the push buttons screwed down to the syphon and to remove them just turn the ring around them anti-clockwise.
Aug 22, 2014 | Home
Is it possible to replace just the cistern instead of the entire toilet set? I have had water leaking problem in my toilet. The water is running from cistern to the bowl whenever the cistern is fille
It is likely that the leakage is being caused by a worn-out flapper or seal (the part the flapper seats on). You can buy after-market kits that have replacement parts. What is the make and model of your toilet?
Nov 30, 2017 | VitrA Aria Toilet with Elongated Bowl/...
How do you get the lid of the cistern?
Dear i_mckie224,
Most toilets you will find that the cistern lid should lift off without the need to remove any screws, nuts or bolts. some on the otherhand, such as the Dudley Elite, sometimes has a screw on the top of the cistern that you need to turn in order to remove the lid, but generically, as said, they should either lift or slide off. If you can provide me with more details about the toilet itself, then I will be able to assist you in finding the answer
Yours sincerely
Oz
Feb 28, 2011 | Toto Home
Cant get the lid off a push button cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to left out the second button, then release the first button and pry that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Feb 01, 2011 | Duravit 0910100005 Happy D Toilet Cistern ...
It is blocked how do i unblock it
Turn off electricity to saniflo.Turn off water to toilet (normally an inline valve). Empty toilet bowl and cistern of water. Remove toilet, cistern. Disconnect inlet pipes to saniflo (careful as backed up water will flow out!).
Take out Saniflo (outside is normally good). Open up top with star driver and use a flat blade for the plastic retaining flaps.Be sure to wear rubber gloves to keep out germs from cuts etc on your hands.
Cover mains cables with plastic food bag and tape up. Use a solution of bleach / warm water, fill up the sanifo and leave for a while. Swish around and empty into a drain etc. I also use a hosepipe to make sure I get it really clean (esp under motor and float switch). Also check inlet pipe flappy bit and the actual pipes that connect to the saniflo
Good luck
Dec 19, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Oct 29, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
When cistern fills with water it leaks into the bowl
This is caused by the 'syphon' mechanism sticking, quite often nowadays the 'brilliant' plastic push button/ syphon combo sticks, and most toilets are fitted with an internal overflow, lift the lid on the cistern and check for anything causing an obstruction.
More often than not, it's a tiny bit of scale that causes such a headache, and the fact that nothing is made with any quality nowadays!
If you can't see what's wrong call a plumber, he/she will solve it.
I hope this helps
Steve
Jul 09, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Saniflo & Saniplus& Macerator Pump  Logo
60 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
