Question about ASUS K52F-BBR5 Notebook
Monitor don;y work,i even hard it plug in the another moniter with a cable and still nother
Modol asus m70v
  • ASUS Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard or you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop your graphics card might be dirty of faulty
Hope this helps.
Posted on Jan 19, 2013
Monitor is displaying only black but other lights are working
My first suggestion would be to check that your cable between it and your video card is secure, even unplug and plug it back in as a test. That is the easiest and cheapest fix, but your problems could be much worse, such as a hard drive or motherboard failure on the PC itself. If possible, try starting your PC using another monitor. If it starts normally then the issue is either with a loose monitor cable or perhaps the monitor is faulty...Good luck! :)
May 08, 2014 | ASUS Computers & Internet
Connect wii to vga moniter Hp s2031
Hi Dear Friend,
You have a monitor with in-built VGA Port and you have laptop in-built VGA Port then why you are not using simple VGA cable to both port, Please don't use any other type to Adapter.
Thanks to Visit on Fixya
Sep 13, 2012 | HP S2031 20-inch Diagonal Lcd Monitor -...
I have an ASUS computer and moniter. when I turn the computer on, the fan inside is really loud, and all the moniter does is show the ASUS logo and it says `No Signal`, and the moniter turns off but the...
Hello
That is a video device problem.First you need to check you monitor cable,it runs from the monitor into the back of the pc into your video device.
Hopefully you have a video card,but check that the cable is secure and tight.You may want to remove it and put it back on just to be sure.
If this doesnt help try restarting the pc and hold the f8 key down and select safe mode.If you get a picture on your monitor you may need to reinstalll the video drivers.If not then you have a bad video card or a bad video chip depending on what is in your pc.
Dec 02, 2010 | Computers & Internet
My moniter says no signsl but the windows is working and i checked the moniter to my laptop and it works fine
Believe it or not but theirs an order in witch you should connect up a compute,r but first make sure that there is only 1 VGA port ie (monitor socket) on the back of it. But if theirs 2 then try the other one.
Other than that try this:
Unplug EVERYTHING! even the power leads from the back of the monitor & pc.
1.Press the power button on pc & monitor to flash out any power left in them.
2.plug in & tighten the VGA cable to the pc then to the monitor if required.
3.plug in all other peripherals ie USB / MOUSE / KEYBOARD etc...
4.plug in the power supply to the monitor then the pc.
4.Switch on the power supply to the monitor first then the pc.
5.Switch on the monitor by it's power button then the pc right after it.
Jul 02, 2010 | Acer X193W LCD Monitor
When i turn on my system unit, my monitor also doest turn on
please change your data VGA cable and then oper your moniter.
Jul 31, 2009 | ASUS P5S800-VM Motherboard
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Hanspree monitor says,''No signal input check video cable''
ask the shop for a replacement cable. it could be broken.
Mar 26, 2009 | Computers & Internet
Male moniter plug on both moniters(every one in the world) and motherboard
That Male connector is a serial port not video, you need to get a video card and plug the monitor to this card.
thanks for rating
Jan 10, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Oct 06, 2007 | Gateway FPD2275W LCD Monitor
Connect Playstation 2 to computer monitor
try going to your local radioshack and asking for a cable to do it. Tell them it needs to be "double male" infering that the piece sticks into another part instead of bieng stuck into. Then tell them one end needs to be "RCA cables" (the red white and yellow ones) and the other end needs to be a computer moniter cable. There are several types of moniter cables you can use, look in the back of your moniter to see what you have. There should be writing that says any 1 of the following "s video in", "dv in" "video in" etc. ask the radioshack man to get the non RCA side of the cable to have one of these on it. If you need to, it helps to take a picture of the back of the moniter where all the input plugs are, and show it to the radio shack man, he can probably help decide which cable to use. Once you buy the cable, plug the red yellow and white side into the red yellow and white holes respectively on the PS2, and the moniter cable into the moniter. Turn on the moniter and the PS2 and... Voila. PS You may need to take out the cable connecting the moniter to the PC to put in the new radioshck cable. I hope this works for you-BCA
Aug 26, 2007 | Sony PlayStation 2 (PS2) Console
ASUS K52F-BBR5 Notebook Logo
29 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
