Question about Neff U1661 Double circotherm super Electric Oven
Neff U1661 Bottom Oven Grill retainer has come off and wont go back
The retaining clip for the bottom oven grill has come off the nipple which holds it in place and when you try to attach it just keeps dropping off, I dont wont to have to replace the oven because of this small bit but the grill hangs down onto the top shelf meaning I am a shelf down anyone any ideas how to re-attach so it holds the grill up
SOURCE: neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Posted on Oct 20, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
Posted on Nov 21, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff U1421W2GB/02 Double Oven Grill problem
There are a couple of solutions to this prob,
You can get some plastic metal and build up the corroded area after cleaning it first, then you can drill a new fixing hole for screw.
The other thing you can do is to cut a small metal plate to fit over bad area, drill and fix it to oven liner, again drill a new fixing hole for element to be secured.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • 44 Answers
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Posted on Mar 19, 2009
barkencoa
  • 3463 Answers
SOURCE: Have had 4 Neff oven elements in 2 years.
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Posted on Feb 07, 2010
Neff U1422 bottom element faulty, is it needed?
the only problem might be hat the oven will not come up to proper temp with out that element .
Oct 16, 2015 | Neff Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Top oven temp display shows 4444
Control panel needs to be replaced. It may also be an error code for the repairman.
Jul 22, 2012 | Neff U1661 Double circotherm super...
AEG D2100-4 , THE TOP GRILL HAS FALLEN DOWN AND THE RETAINING SCREWS WONTS GO BACK ANY IDEAS THANKS
Hi the spare part solution is to replace the oven liner. not economic and difficult to do. If engneering minded you can make a long slide clip i have made some out of an old oven shelf grid.forming a shape similar to a tent peg in shape and size and sliding it horizontally through the grill retainining bracket and hole in the oven liner. not easy to explain this but it works on aeg bosch and neff ovens with the same fault.
Nov 09, 2010 | AEG D2100-4 Electric Double Oven
How do you change the grill element ? on a Neff U1421N2GB/05
screw at top of element is for support.. there are either 2 screws at the rear of element bracket holding it or access to behind the rear panel is required as there are 2 nuts holding the grill bracket to rear cavity. please make sure power has been disengaged before attemt to repair..
Dec 21, 2009 | Neff U1421 Double circotherm Electric Oven
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Hi.
Good luck
Nov 21, 2008 | Neff U1661 Double circotherm super...
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Neff oven door (U1661)
Oct 20, 2008 | Neff U1661 Double circotherm super...
Oven no heat
check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
Jan 16, 2008 | Neff B1641 Single circotherm super...
Neff U1661 Double circotherm super Electric Oven Logo
42 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
