Question about Air Tools & Compressors
Unitor impact wrench - Air Tools & Compressors
3 Suggested Answers
  • 111 Answers
SOURCE: Oiling a Sears 900.275132 impact wrench
use air tool oil and put a couple of drops where the air plugs in.
Posted on Feb 21, 2010
SOURCE: Dont know where to put oil in Craftsman 1/2 " Impact wrench
I just bought one of these also. Manual says oil goes into "the air inlet" which I'm thinking is where you attach the hose. That way the oil is sprayed throughout the interior of the gun once you run air through it.
Question for you: I can't get an impact socket onto this gun, almost seems like the square hole is too small. (yes, both are 1/2" drive). How do you get a socket on this stupid thing?
(man that sounds like I'm an idiot, but I've spent a half hour leaning all my body wight, wiggling, etc. and can't get a damn socket on)
Posted on Jun 20, 2010
What is causing my 3/4" Makita electric impact wrench to overheat and slow down
remove the back cover and use some lube that is safe for electric handtools
Jun 19, 2014 | Makita Impact Wrenches 3/4" Impact Wrench...
Do I need to put oil in a brand new Titan 24volt impact wrench
I have never used that brand of impact, but I have used many others and I have never known an electric impact or drill to need oil. You need oil in an air powered impact because the air motor needs lubrication. The electric motors in electric impacts have sealed bearings and brushes that are meant to run dry. The actual impact assembly should be sealed as well, it should not need any oil.
Jul 13, 2012 | Titan 24v Cordless Impact Wrench
Hammer on Makita model 6905H corded impact wrench 1/2 size broke.
go to web site there is a parts list for your model and order the part
May 01, 2010 | Makita 1/2" Corded Impact Wrench
Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Apr 16, 2009 | Impact Husky® 1/2" Wrench
Air Wrench Question
An impact wrench works in the manner suggested by the name of the tool: through the principle of impact. In order to understand how an electrical or air-powered impact wrench works, it helps to know first how a manually powered impact wrench operates. A manually powered impact wrench looks like a fat screwdriver; on the end where the screwdriver blade normally goes, you can snap on screwdriver bits or sockets.
Aug 27, 2008 | Ingersoll Rand 271 Super Duty 1 Inch...
Wrench Support
An impact wrench also requires a few special accessories. An air-powered impact wrench runs off of an air compressor with a tank – the air compressor should have at least a 10 gallon tank and be able to generate at least 3hp. Also, an impact wrench requires special sockets that are designed to withstand the high torque applied by the wrench.
Aug 27, 2008 | Impact 3/4" Dr. Heavy - Duty Air Wrench
Wrench support
impact wrenches are often misused by those who don’t know about their special needs. First of all, it is very important to be careful when tightening a nut or bolt with an impact wrench! Cross threading can occur very easily; a novice may also over-torque a bolt or a nut if they don’t know when to stop. To prevent such problems, always be sure to hand-tighten every nut or bolt before using the impact wrench; if you try to start the nut or bolt with the impact wrench, you won’t be able to feel if the threads are crossed. If the impact wrench is not torque controlled – meaning it will stop when the nut or bolt is tightened to a certain torque – you will need to go slowly, and periodically check the torque value of the nut or bolt to make sure you haven’t tightened it too far.
Aug 27, 2008 | Campbell Hausfeld 1/2" Impact Wrench
Wrench question
Aug 27, 2008 | Porter Cable Cable Factory - Reconditioned...
Air Tools & Compressors Logo
37 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
