Question about Harman Multimedia HK 3385 2 Channels Receiver
I have hk 3390 reciever
I have a hk 3390 reciever but i have problem connecting it to an IMac
  • 3 Answers
What I did is bought a splitter, plugged it in the headphone jack at the back of the iMac. One side goes to my computer external speakers and one to my receivers aux input, or tape one input. I works, just make sure that the volume on your iMac is not higher than half way, or your sound might be distorted and your external computer speakers are off. Not unless you want them on. Keep your iTunes EQ set to flat, that also will create unwanted distortion. Use you receiver tone controls if needed. Hope this works for you, that's how I did it.
Posted on Jan 19, 2013
Connecting 4 ohm speakers
I don't think it has anything to do with the impedance. The amp and speakers are well in the allowed limits. The only time this is a problem is if you connect an amp with a greater impedance then the speakers.
This sounds like something to do with the HK 990. It could have a fault on it. You could try listening with headphones if the HK 990 has a socket for them. If they have low sound, there's an electrical fault in the power amp of the HK 990.
Jun 09, 2012 | Harman Kardon Harman HK 990 Amplifier
The reciever does no respond when I press the remote control even after changing batteries by new ones. however, the reciever responds well when controlled by pressing the bottons located on the reciever....
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?
a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 03, 2011 | Harman Kardon HK 3270
I can;t get my toshiba tv 42 to connect to the hdmi
ensure that you are connecting input to output.
if you are sending the television signal to the receiver.
ensure your tv output is going to the receiver input
if you are looking at
dvd or blueray through the receiver to the tv.
ensure that your ouput from your receiver is going to an input on your tv.
I hope this was useful.
Jan 11, 2011 | Harman Multimedia HK 3390 Receiver
How do i connect my boston acoustics pv800 subwoofer to my Harmon Kardon AVR 520 reciever?
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Jun 06, 2010 | Boston Acoustics PV800 Subwoofer
I have my new HK3390 hooked to my legacy Polk monitor 7s. The Ohms and Wattage match pretty well. I have the positive hooked to the positive and negative to the negative. I only get a tiny bit of sound...
Never troubleshoot anything with the volume cranked up. The moment you find the mispositioned control you'll damage your speakers. If something isn't audible at half volume there's a problem.
Are the speakers activated?
Check that MUTE is not turned ON.
Make sure you don't have any Tape functions selected without a corresponding device attached and functional.
May 27, 2010 | Harman Multimedia HK 3390 Receiver
How to unlock nokia 3390
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
Nov 23, 2009 | Nokia 3390
HK 3480 sound suddenly cuts out
your fuses are blown by possible crossing speaker wire - and + together. I did this and kept turning it on but I ended up frying the unit. Check your wires and make sure that they are seperated properly. If problem continues then unscrew the shell and replace 1 or all 3 fuses (depending on what was blown) with GMA 8 amp fuses. good luck.
May 23, 2008 | Harman Kardon HK 3480 Receiver
Amp comes on and goes right into protection mode
Turn the reciever on for a second or two and then off before the protect mode shows up on the monitor. Repeat this step about five times and check to see if the reciever does not go into protect mode. If it does go into protect mode try it again. Dont know if this is the proper way to fix the reciever but it worked for me. Good Luck
Mar 09, 2008 | Audio Players & Recorders
Harman Multimedia HK 3385 2 Channels Receiver Logo
54 people viewed this question
Top Harman Multimedia Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
