Question about Panasonic Cameras
My Panasonic DMC FS42 won't work AT ALL
Well, I was zooming in on my pictures one night, and it just stopped working, everytime I go to playback it won't work at all, none of the buttons work, it won't let me take any pictures and at the bottom of the screen it says something like "0.17 ft - a sideways 8" the has a rectangle with "EZ W and att the end of the rectangle it says T 1X" someone help?
    Genius:
  • 1,019 Answers
The camera has a serious malfunction, it sounds like the control unit for the zoom has failed. this is camera shop time. no user fix. no reset.
Posted on Jan 26, 2013
SOURCE: Panasonic Lumix DMC-LC1 Digital Camera Problem
Contact Panasonic - there is a widespread problem with CCDs in the last 3 or 4 years - keep pressing them for free repair as is your due with faulty goods, even outside the warranty period.
See the following link:-
Widespread CCD problems in consumer imaging productsCCD Sensor Problems in Consumer Imaging Products .... Given that the Leica DIGILUX 2 is a variant of Panasonic's Lumix DMC-LC1 design, it isn't surprising ...
www.imaging-resource.com/badccds.html - 51k - Cached - Similar pages
Posted on Feb 25, 2008
  • 16 Answers
SOURCE: panasonic lumix dmc fz18 won't zoom in or out
The innards of modern DSLRs are precise and fragile. You need to contact a reputable repair shop ASAP. In addition to fixing your camera, they will clean the interior properly, eliminating dust particles that find their way to the CCD. The cleaning is something you should have done from time to time anyway, so just bite the bullet and take it in!
Posted on Sep 05, 2009
  • 83 Answers
SOURCE: I have a Lumix DMC FX3..great butr is stuck in
Hmm, looks like the zoom rocker switch might be stuck. To get to the switch you'll need to partially strip the camera. This is a bit fiddly, but should be ok if you are comfortable with taking things apart. I repair cameras as a hobby and in my opinion lumix-es are by far the easiest to take apart and put together.
Remove the battery, unscrew all the screw holding the case making notes which screw goes where (they are not the same). Very carefully lift the back of the case to see two white ribbon cables going to LCD screen. Disconnect them. Once done, remove the front of the case. With both case panels removed pull off the top section (where the power, shutter/zoom buttons sit). This will require a bit of force. Once done, you'll need to undo the plastic cover, there should be a screw or plastic catches holding it onto the small logic board. A word of warning, there is a flash capacitor attached to the board (looks like an AAA battery). This can potentially electrocute you (won't kill you but is not very pleasant) , so try not to touch the tracks/connections on the board. Once you expose the top of the board you'll be able to see the zoom rocker switch (a little silver square thingy with a black bit sticking out). The black bit is the bit which is stuck. Try to move it (gently). It should stay in centre position. Well, that's it. Put the camera together and hopefully it's back to normal.
Hope this helps.
Raf
Posted on Nov 05, 2009
  • 125 Answers
SOURCE: GOT A PANASONIC DMC-FS42 WHEN I SWITCH IT ON ALL I
Look here:
http://www.fixya.com/support/r4696998-camera_lens_not_extend_retract_maybe_bat
GL
Posted on Jun 16, 2010
lock123
  • 6831 Answers
SOURCE: system error (zoom) camera frozen Panasonic Lumix DMC-LZ28
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
My panasonic Lumix camera DMC-ZS3 dropped and the zoom stopped working. Lens will go out only a drop, not enough to take pictures, and it says: "system error: zoom." Playback only is OK. Is this...
there is not a big problem if the lens are coming out but not enough..the mechanism is blocked i think will cost about 25$ or something like that
Oct 06, 2010 | Panasonic Cameras
What is the part number for a panasonic lumix dmc-fs42 lcd screen?
The part number for the LCD screen (display) is: VYK3H41
For more details and part numbers, click here. Enter dmc-fs42 under model number.
Hope this solves your problem. For more help and clarifications, please feel free to reply to this post.
Thanks for using FixYa.
Jun 30, 2010 | Panasonic Lumix DMC-LS80 Digital Camera
I have a Panasonic Lumix FS42 with an sd memory card. I cannot download the pictures from the memory card onto my computer even when the memory card is changed into a different camera???
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 21, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
I have a panasonic DMC-FX5 memory card error
I'm assuming the slide switch on the side of the card is in the unlocked position. Have you formatted the card in your other camera or does the card contain pictures taken on the other camera? This could be the problem. To get the card to work in your FX5, download any pics from the card to your computer and then, format the card in the FX5. In the future, don't use the card in more than one camera.
Jan 14, 2010 | Panasonic Lumix DMC-FX5 Digital Camera
Panasonic lumix dmc fz18 won't zoom in or out after being dropped from a table. the camera can still take photos but not zoom on playback or while taking photos
Sep 05, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
Panasonic DMC-TZ1 operates in Playback mode only
The position from the dial wheel is not corresponding with the electrical position. If you can do it by yourself you can adjust it and tighten the midscrew from the dialwheel
Regards, Rob NL
Apr 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Cameras Logo
37 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
