Question about Dell Latitude E6400 Laptop
My e6400 laptop with dell 1510 wireless minicard sees networks via netgear dg834gt router but will not connect. I have changed channels, updated drivers, checked diagnostics on card, played with settings and will not connect at all. Hellllp please?
  • slw1535
    slw1535 Jan 20, 2013
    Doh! I entered the MAC address of the wireless card into the router access setting and ping! Thanks for your help
  • Dell Master
  • 27,725 Answers
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Posted on Jan 19, 2013
Geekman
  • 32281 Answers
SOURCE: wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Posted on Feb 03, 2009
Nic61
  • 1073 Answers
SOURCE: Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Posted on Dec 05, 2008
NitrusInc
  • 326 Answers
SOURCE: I have problem with my vostro 1510 wreless, by switching the wireless and bluetooth key on, only the blutooth devise is turn on.
The Dell QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
It is known to glitch when power is removed from the machine while the wireless is in use.
Please let us know if you have any futher questions. If this information was helpful, please take a moment to rate the solution. Thank you.
Posted on Apr 23, 2009
NitrusInc
  • 326 Answers
  • 10 Answers
SOURCE: Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Posted on Jun 20, 2009
HOW DO YOU CONNECT A BLACKBERRY PLAYBOOK TOA NETGEAR DG834GT ROUTER?
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 15, 2012 | Computers & Internet
Cannot access wifi Netgear DG834GT
Hi Andy
Just a guess. The Netgear may be transmitting that your pc cannot connect to. ie. there are 3 'formats' (for want of a better word) that go under the names B,G and N. I'm simplifying now, B is the original wireless system that we all used. G is the much faster system that most recent machines use and N is the newer system that your router does not use. Your router can use B and G or B or G. I'm guessing that it might be set to B only and your machine is G or N. Theoretically It shouldn't make much difference but I have heard of instances when the newer machine cannot connect.
Of course I may be completely wrong and it's something else. I had an instance where with 2 laptops in the same room only 1 would access the Netgear but the other (although it could see it and would not lock on) would lock on quite happily to an open network transmitting from an adjacent building. After some hair pulling and cussing, I changed the transmitter channel on the router from 10 to 2 (or something completely different) and suddenly both laptops would lock on to the netgear without any issues.
Sep 27, 2009 | NetGear DG834G Router
Using a notebook PC's internet signal to go online with a PS3
you could connect your laptop to the internet and then connect your ps3 to your laptop either via wireless or cross over cat 5 then make a bridge between your internet connection and which ever connection you conected your ps3 to.
Sep 10, 2009 | Dell Inspiron 1521 Notebook
How do I disable my DG834GT router firewall?
The router firewall only blocks connections coming from the internet.
Basically it only lets an outside IP connect to your network if you establish the connectoin FIRST.
The most common cause of not being able to see another PC on the LAN is not having the same workgroup name.
Go to Start > My Computer , right click > Properties > Computer name. Make sure all PCs have the same workgroup name.
Mar 05, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Wireless card in E1505 Dell not finding networks in range
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Cannot connect wireless device
If you have the correct wireless security and the laptop wont connect wirelessly, the best thing that you can do here is to access the router setup page and change some wireless settings on the router like the wireless channel , I advice you set the wireless channel to 11 then after that try to connect your laptop again to the wireless network and by the way change also the SSID or wireless network name of the router....
Nov 04, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Wireless connection
Did you change your wireless SSID and channel? Better to enable encryption too. If this problem never happens when you're connecting to other wireless networks you might as well update or reload the firmware/software of your router.
May 22, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Problem linking my wireless laptop into newly installed network
you may have to turn on the wireless feature in the router.netgear will help you to fix it.go to their site or call them for help.
Jan 07, 2008 | NetGear DG834G Router
Dell Latitude E6400 Laptop Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
