Question about HP Photosmart 2710 All-In-One InkJet Printer
Help connecting HP 2710 wireless to my PowerBook G4
I had a flood and had to move my G4 computer and HP2710 to another location.  I have an Airport wireless system set up and an answering machine.  I cannot find my HP instruction book (put in a "safe" place during the flood) and need help setting up the fax and printer functions.  Can you help?  Is there a fee?
  • eaglemac99 Jan 26, 2009
    rtrahan:
    The HP2710 is my printer model number.  My computer laptop is a Mac PowerBook G4.  This computer has been linked to this printer before the flood in my house.
  • Anonymous Mar 31, 2014
    Do I need to organise wireless connect for each home I have
  • 741 Answers
No, there is no fee. I will help you figure it out. However looking thru the HP manuals is the HP 2710 your printer model number or your notebook? I found manuals on notebook.
Don't forget to rate this solution before you log out.
Posted on Jan 26, 2009
  • Randall  Trahan
    Randall Trahan Jan 26, 2009
    I was able to find the manuals for HP 2710 All-in-One printer. However, because we are not authorized to send emails to personal accounts I can only give you the steps I used to find it;
    www.hp.com
    click on support and drivers
    Step 1: click on support and troubleshooting
    Step 2: type in hp 2710
    select from the list hp 2710 all-in-one printer
    next page has the manuals/setup guide and user guide
    if this is not the correct one let me know.
My powerbook g4 no longer recognize my builted in airport, have no airport now. The only way to make my g4 work in hook an either net cable to my g4 into my router. Makes my laptop very stationary, what...
What I would suggest is reseating the airport card as it may be the card has come loose or the cable is not connected properly. The following support page on the apple website will tell you how to do it.
support.apple.com/kb/HT2617
Failing that you will probably have to buy an new airport card or a wireless usb adaptor. You should be able to pick one up from ebay fairly cheaply.
Hope this helps.
Apr 17, 2011 | Apple PowerBook G4 Mac Notebook
Display won't turn back on
You may need to open it up again and remove first the airport card and turn it back on and if that boot your computer there's a possibility that your airport is causing the problem and the airport may be loose and touching some other parts on it.
Hope that helps...........
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
I have a Powerbook G4, and suddenly my airportcard stopped workin
OSX has become unreliable.
You could spend hours troubleshooting, or simply backup and re-install from disks, takes about 40 mins
Jun 20, 2010 | Apple PowerBook G4 Mac Notebook
Airport card disconnected
There is no Macbook pro G4 (macbook pro are using intel chips) please clarify
Jan 19, 2010 | Apple PowerBook G4 Mac Notebook
Power problem on HP2710
I just gave the printer to the repair shop that wanted to charge me $30 to diagnose the disease.
Vokes
Jan 28, 2009 | HP Photosmart 2710 All-In-One InkJet...
I just bought a used powerbook g4 laptop. It worked great and I used it at work to connect wirelessly to the internet. I brought it home and cannot get it to connect to my wireless network. I have a belkin...
You could try changing the security. Some of the older laptops have trouble with the new WPA2 security. Use WEP and you should be OK if this is the problem. Good luck TT
Dec 13, 2008 | Apple PowerBook G4 Mac Notebook
MacBook not connecting to DIR-655 Router
My solution was that I changed the wireless mode from "B,G and N" to just "B and G," and then it worked fine.
Nov 23, 2008 | D-Link Xtreme N DIR-655 Wireless Router
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
Airport connection - G5 Powerbook
Yes better get a new wireless card if there's a airport that can be connected via USB that will be better..
Good luck....
Apple Powerbook G4 17in 1.33Ghz. Tiger OS. Airport problem.
I had a similar problem with my 15" 1.33GHz powerbook G4.
My problem was I couldn't connect to a network right away or at all, or wouldn't properly reconize the card (didn't drop it).
I solved it by removing the airport card from my PowerBook and putting it back into my G4. it should be in the same location.
it's underneath the battery pack.
1. power off your G4
2. remove battery pack
3. there is a latch on the right side (if the charger port is facing down), open it
4. pull back plastic cover tab and gently remove the antenna plug from the airport.
5. pull the plastic tab, until the airport card is removed, keep out for 30+ seconds to ensure it erases any corrupt log file on card it's self.
6 place airport card into the slot again, fully inserting it, it should go 1/8" - 1/4" into your powerbook
7. plug in the antenna plug back into your G4's airport(it should click 2x(very lightly)), flip plastic tab back over top the antenna cord, close you latch.
8. place battery back into your G4
9. plug computer in, turn on and it should work
if not then there is something wrong with the airport card reader, which i don't think it's the case here..
Jan 12, 2008 | Computers & Internet
HP Photosmart 2710 All-In-One InkJet Printer Logo
118 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
