Question about Microwave Ovens
Total power loss during use
I installed this microwave 2 days ago. It is an over the range model Tappan TMV151FS. I was warming a frozen entree for 12 minutes and 5-6 minutes in to the cycle the unit totally powered down. I checked the outlet and there was still electric available. After about 20-25 minutes the unit came back on (not running but the display lit up). So I set the cooking timer for 6 minutes and after 3:32 minutes it powered down again. After 27 minutes it powered up again.
The kicker is that this is the 2nd one I have had do the same thing. The last one started doing this after 6 days.
Is there a problem in how I have installed the unit or some install instruction missing in the install manual? It heats fine when it runs but this problem is not acceptable. Any ideas?
Charlie D
  • Anonymous Mar 24, 2009
    Power went out completely on my TMV151FS over the range microwave oven. Then it came back on within 10 minutes.
  • largeone Mar 26, 2009
    I have the same problem. Voltage is good and so is the polarity.
  • 56 Answers
Check the voltage on the outlet,make sure it is 115v -- 122volts max, any less will cause it shut off, make sure the polarity off the outlet is correct and it is grounded,check all of your wiring connections, if all this is ok replace unit with a different unit or different supplier of unit
Posted on Jan 26, 2009
Everything on our microwave works except the most important part-its not heating. TMV151FS
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Mar 09, 2011 | Tappan Microwave Ovens
"SE" means you have a shorted membrane keypad.
The most economical repair (and a pretty simple one) is to replace your entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Model TMV151FBA is black and model TMV151FSA is white.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You would order one of these here:
5304456080 Control Box, assembly, black $145.14
5304456081 Control Box, assembly, white $149.42
Sep 07, 2010 | Tappan Microwave Ovens
Tappan over range has no heat!
You have a bad high voltage diode, bad filter capacitro or a bad magnatron. The diode and capacitor does not cost very much. You can get them at . Replacement would mean removing the unit from under the counter, remove the case. Locate the diode and capacitor. They should be near the power section and the diode is attached to the chassis and one side of the filter capacitor. After replaceing both parts if the unit will not heat you would need a new magnatron. The part is fairly expensive but depending on the cost of your unit it may pay to replace it. Let me know if you need anymore help.
Thanks for using FixYa
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Filter replacement
That's covered on page 20 & 21 of your owner's manual under the heading"CHARCOAL FILTER REPLACEMENT"
1. Unplug oven or turn off power at the main power
2. Open the door.
3. Remove the two vent grille mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number from the tag on the oven here.
Feb 16, 2009 | Tappan TMT104E1 Microwave Oven
User manual for a Tappan mod TMV151FS
You can download your owner's manual here.
Jan 01, 2009 | Tappan Microwave Ovens
Over the range microwave
I would return the unit and get a different model or brand if possible.
Jul 07, 2008 | Microwave Ovens
Microwave Ovens Logo
341 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
