Question about AMP Fuse Wiring Panel
I cannot start the car.
I put the key in the ignition and when I turn the key nothing happens
    Sergeant:
  • 248 Answers
Clean your battery terminals and check the battery has healthy charge. If this is not the problem it is the main fuse or your starter motor.
Posted on Jan 19, 2013
Ignition will not turn
The key won't turn in the ignition switch? Or when the key is turned nothing happens?
May 31, 2016 | 2002 Cadillac Deville
When I turn the key nothing happens. No clicks, no crank. All of the lights work properly. No dimming or turning off when I try to start. This has happened a few times before. The first time I put the car...
Ignition switch....the electrical ignition switch. To verify, find the thick white wire in the harness coming from the switch and do two things; first, check for power at this wire, when you switch the key position to start. If nothing, power the wire momentarily with the key in the run position, and your car should start.
Sep 11, 2013 | 2003 Hyundai Accent
2008 dodge grand caravan key
ignition keys worn out or ignition switch faulty.
Jun 21, 2013 | Cars & Trucks
I put key into ignition, turn to start, nothing happens.Turn key of and try again,after several attempts,the van will start ok. This problem does not happen all the time, but is happening more frequently...
From your description of the problem, I would suspect either the ignition switch itself is starting to fail (large heavy key rings hill help that along) or your starter relay on the fuse panel. You can swap the relay with another like relay on the board and see if the problem moves or just replace it.
Jul 16, 2011 | 1999 Dodge Caravan
Tried to start the truck---nothing happened....the ignition key was turned on but nothing. 3 days ago, same thing happened I turned key and nothing. So what I did---turned key on till red light came...
sounds like a bad connection,it wont heat up the solenoid or the starter,check your hot and negative cables from battery to starter first could be the starter itself, ggod luck
Dec 20, 2010 | 1997 Chevrolet C/K 3500
For the last five years that I have owned my 2004 Chevy Impala I have had problems with it not wanting to start at certain times, usually and mostly during the summer months, but not all the time. I get...
I had the same thing happen to my impala. It was the sensor in the ignition switch for security purposes. I had too many keys on my key ring, and it caused the ignition switch to not read my key right. Once I had the ignition switch repaired, I don't put so many keys on my key ring. It cost me about $300.
Sep 27, 2010 | 2004 Chevrolet Impala
2002 Pontiac Grand prix wont start; unable to remove key
On many cars, if the battery is dead, it locks the key in the ignition. Put a battery charger on the car or replace the battery and give it a shot.
Good luck.
May 15, 2009 | 2002 Pontiac Grand Prix
Engine does not start?
Make sure that the connections at the battery is clean and free of acid built up. Take the terminals of and clean them propperly
It could also be the ignition switch at the wiring end not making proper contact anymore, try and wiggle the ignition wiring if possible and see if there is any change in the status when the ignition is switch on
Oct 26, 2008 | 1988 Nissan Pulsar
AMP Fuse Wiring Panel Logo
Top AMP Car Audio & Video Experts
bigdawg7299
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
