Question about Universal Power Group 12v 50ah UB12500 Wheelchair Battery replaces 40ah, 42ah or 50 ah
Can i use a 12v 50ah car battery on my mobility scooter?
  • Universal Po... Master
  • 1,271 Answers
, hi ,well you will need two of them for a start( 24v) , GEL batteries can supply much more amp than a car battery for a longer given time, where a car battery will start to drop off voltage wise a good GEL will hold up the voltage for longer, this is the important part most mobility scooter controller will start to cut out around 18 volts or less.
Regards
GeWiz.
Posted on Jan 20, 2013
I have an Invacare LEO mobility scooter is it possible to up grade the 12v 35ah batteries to 12v 50ah for a greater distance, If yes would I need a different charger? Thank you.
Hi u can use the same charger::: the batteries are a bit bigger ::: check if they will fit in you're battery compartment length mm 225. Width 135 mm
Height 216 ....
35 amp batteries size :::: length 195 mm. Width 130 mm height 159 mm.....cheers
May 04, 2018 | Invacare Health & Beauty
How to wire two extra 12v batterys to a 24v mobility scooter to increase the amps
Connect the two extra 12 volt batteries in series to get 24 volts. Then connect this new 24 volt supply in parallel to existing 24 volt battery supply.
Jan 30, 2017 | The Health & Beauty
Are 12 AH batteries correct for a Wizard4 German Scooter?
hi please confirm by looking at the pictures what one your scooter is
Wizard 2 Folding Mobility Scooter Silver Self Assembly
Pharmore Mobility
if so they are 12v 12ah batteries...
Regards
Rob
Sep 28, 2016 | Health & Beauty
What type of batteries does this model take?.jb.
you need 12v 33ah sealed deep cycle battery most likely it may need two batteries any thing above 33 amp hours would also be ok. A higher Ah the longer the batteries last. This information on the type of battery is from the user manual.
http://www.hardwarexpress.co.uk/rascal-388-mobility-scooter-battery-1949-p.asp
Any battery type store should be able to supply this to you .
Feb 10, 2015 | Electric Mobility Rascal Scooter...
Can you jump the batteries on the TSS300
If you mean jumping the batteries like you would a car; no this not possible with the AGM batteries. You should have 12v 32-35AH AGM batteries in the TSS 300.
Apr 26, 2014 | Electric Mobility 4 Wheel Heavy Duty...
Pride jazzy 1120
Page 44 of the manual for your chair specifies size NF-22 batteries if the power seat option is installed, otherwise size Group 24 can be used. (See this battery size table.) You should use batteries with the highest amp-hour rating that will fit and you can afford; the amp-hour rating determines how long you can run on a full charge. Evidently the power seat mechanism takes up space needed for the Group 24 (79 Amp-hour), so you have to go to the somewhat smaller NF-22 (55 Amp-hour). Don't mess around with a 50 Amp-hour battery at a higher price when the 55 A-hr units will fit.
Dec 02, 2013 | Health & Beauty
Batteries die fast on my mobility scooter.
Hi. What size batteries you buy will be limited to the amount of room you have in the machine.
17 amp hour batteries are really a bit small for any mobility equipement. A lot of power chairs have 35 or 40 amp/hour batteries.
Buy the biggest that will fit into the available space.
Batteries are designed to perform a certain number of "charge cycles". If you run your batteries down by 75%, you will only get a small number of "charge cycles". If you only use 25% of the batteries capacity, you will get 100's of "charge cycles".
The best I have seen is 7 years out of a set of batteries. Short trips and recharging after each trip is the reason.
Good luck. Neil.
Jun 03, 2010 | Electric Mobility Pacesaver Electric...
Pride hurricane batteries (2008,model)
Hi...
You'll get a little more time out of the 55ah ( like 10%)
Mar 31, 2010 | Pride Hurricane 4 Wheel Personal Mobility...
Replacing the battery on a mobility scooter
hi, ok remove the seat by turning it to the left, there is a lever normally on the right side that will allow it be turned round,
once you done that, lift the seat in a upwards motion, the cover should come away by gemerally lifting it, it should be attached by velco underneath,
you should now see two batteries. 40Ah batteries will allow you to go further if the battery Ah is lower, 50ah batteries again will allow you can go even further NOT faster, if you buy the larger AH batteries please make sure the dimensions of the batteries will fit within the scooter battery holders.
Regards
GeWiz.
Feb 13, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Universal Power Group 12v 50ah UB12500 Wheelchair Battery replaces 40ah, 42ah or 50 ah Logo
310 people viewed this question
Top Universal Power Group Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Universal Power Group Health and Beauty Expert? Answer questions, earn points and help others
