Error message ld - Washing Machines
  • Lina Jan 19, 2013
    It's a Simpson encore 756 top loader
  • Washing Mach... Master
  • 17,130 Answers
Please mention the make/Model.
Check this link for error codes: error codes
Posted on Jan 19, 2013
Sc 241 ricoh mp c300
LD error
LD error continues for 0.5 seconds. (After LD error is detected, a release of LD error is written to the GAVD circuit during monitoring.).
LD unit defective
Dec 03, 2013 | Ricoh Office Equipment & Supplies
Why do i get a "ld' signal or a "co" message?
LD = Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display
I don't see an CO error. Here is a complete service manual for your washer. I am sure it will come in handy in the future. Look on page 46 for a list of the error codes.
Regards, Rich
Feb 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
What does error code LD mean?
"Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. please remember to rank how this opinion has helped in your appliance situation and if you have any more questions please message me back thank you again and have a nice day
rickead1
Aug 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio giving error message LD-what is wrong
Long drain error can be caused by something plugging the drain hose or a kink. Tale it off th drain while it is pumping out and check for a good flow. If the hose is ok the pump may have an obstruction causing low flow and it will have to be cleaned out.
Mar 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Error Message on Start up
Avery ld machine try buying one on line and replace the main board achip or up grade
Jan 28, 2008 | Minolta Di151F All-In-One Laser Printer
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LG LD-14AT2 - Error message about filter
HI, WE HAD THE SAME ERROR AND WERE ADVISED - AFTER WE CLEANED EVERYTHING - TO NOT USE A LIQUID CLEANER AND USE A TABLET.
Nov 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
