Question about Panasonic PT-47WX49 47" Rear Projection Television
I need to clean my 1997,52 inch rca tv screen
I need to know how to remove the screen so it can be cleaned,please help?its a 1997 rca ,52 inch,serial #p52754atlx2,model # 717590399 please help. thank you
    Genius:
  • 1,199 Answers
OK
Take the screws out of the BACK top panal of tv! be gentle the mirror is connected to this back!.... now after removeing back you will see the inside of screen and the three lenses and on back panel the mirror! clean all three of these and you will see a big change for the better..Then just replace back! (The screen itself does not come out!)
Please take a second to place a rating for my answer!
thank you!
Posted on Jan 26, 2009
tvtek
  • 1284 Answers
SOURCE: screen removal
Screen Removal
There are two types of screens used on this chassis.
Model 1 - with one piece frame around screen.
1. Remove the front grill cloth assembly and remove four
(4) screws along the bottom of the screen frame.
2. Pull out slightly on the bottom of the screen frame and lift
up and out on the top of the screen frame (and screen) to
remove.
Model 2 - with wood piece securing top of screen.
1. Remove the screw access cover plug from each side (near
top) of the TV and remove one screw from each side.
2. Pull up on the wooden strip and remove.
3. The screen can now be lifted out of the tracks and
removed.
Posted on Jan 22, 2008
ladywinn
  • 5138 Answers
SOURCE: sony 52 inch hd widescreen projection tv
You need to pull the top back off be very carefull that you do not break mirror clean mirror and all 3 tube lenses this should make a diffenrents in picture.
Posted on Feb 19, 2008
SOURCE: need a manual
Where can I get a manual?
Posted on Oct 30, 2008
  • 4 Answers
SOURCE: RCA 52 Model # R52WH73
The solder joints are loose on the flyback transformer and that is what is most likely causing the fuse to keep blowing. Resolder the connections and replace the fuse and you should be good to go.
Posted on Jul 24, 2009
SOURCE: RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Posted on Sep 23, 2009
How do I get the cloudiness off my rca 55 inch tv
Take off the screen, clean it with a NON ammonia window cleaner. While it's open look down at the tube faces. Gently clean off the dust accumulation. NEVER try to clean the mirror or touch it either. Cleaning it will ruin the surface of it and you'll always see it in the picture.
Feb 21, 2016 | RCA Televison & Video
How do I clean the inside of the screen
If it is a projection screen you have to take it apart. First lay the tv face down on a bed then remove the screws that hold the back on. Be carefule some of the screws are hidden and most of them are torx bit. Please make sure you dont void any waranty by doing this! When you have all the screws out the flip it back over and carefully pull the face and screen off. This will allow you to clean it. DO NOT use anything but mild soap and water. I hope this helped.
Jul 30, 2012 | Dell W3707C 37 in. LCD Television
I have a 10 year old RCA 50 inch big screen TV with marks on the screen that seem to be on the inside. How do I clean the inside of the screen, thanx Lon
marks inside the tv glass should only be cleaned by a professional because you may damage the extremely sensitive parts of the television, if its not to bothersome to you , you should ignore it as you will probably be charged an arm and a leg for this,(i know from experience)
you can also try adjusting the picture settings until it becomes less noticeable
Mar 05, 2011 | RCA HD50LPW175 50" HDTV
How do i take of the front cover of my 52 inch RCA hdtv? i need to clean out the inside of the tv because spiders somehow got behind the picture...
You will have to remove all the screws on back of TV Front Bottom panel first then you will have more screws that hold Top on in back and under front screen its not as bad as it sounds it just takes awhile to do while your in their clean your mirror and all 3 top lenses to Tubes.
Dec 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA rear projection TV with a dead fly behind the screen, how do I get it out?
pop the speaker grill off, then take out the 1/4 inch screws and remove the screen, if it's behind the screen, simply brust it away, if it's between the 2 screens, then you must take them apart and remove the body. also while your in there, clean the lenses and mirror with some windex, this will greatly improve your picture.
Sep 08, 2009 | RCA P61940 61" Rear Projection Television
The screen on our 52 inch TV needs cleaning-inside and out
The outer screen is a protective screen. it is just glorified plexiglass. just use a soft cloth slightly damp.
Apr 09, 2009 | RCA D52W19 52" Rear Projection Television
I have a RCA 60 inch TV and its about 12 or 13 years old. It has never been serviced or cleaned on the inside. The problem I'm having is the picture is starting to fade (quite a lot)and I was wondering if...
you probably have a little of both. the shutting off is definately heat related but could be too much dust on heatsinks, etc causing it to shutdown. cleaning may eliminate problem but could be a sign of an underlying issue..
the dust can really cause the picture to dim. most of these tvs you can pull the "lightbox" or guts out of the cabinet to clean all 3 lenses, and clean the mirror if needed. don't mess with the screens except cleaning the front from outside. usually a 1/4" driver will be all you need, and a soft cloth for the lenses. use compressed air or a vacuum to clean out dust which will help with cooling, but the picture is only effected by dust on lenses, mirror, and screens.
Feb 18, 2009 | RCA P56950 56" Rear Projection Television
Need to clean the backside of the plexiglass
You dont!!!! You remove the back upper panel screws and remove the back of the TV to access this area to clean! Wile your in there you might as well clean the lenses and the mirror too ( will see a big differnce in the picture!) be carfull with the back when removed! the mirrir is connected to it!
I think this will fix ya up!
Please rate this free response!
THANK YOU!
Jan 17, 2009 | RCA HD52W58 52" TV
Tv turns off after several minutes
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Dec 23, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26 Screen problem
remove spkr grill and a few screws, unplug connectors,remove entire screen assy and clean....reassemble
Aug 14, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-47WX49 47" Rear Projection Television Logo
166 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
