Question about Kenmore 24032\24036 Top Load Washer
Washer outlet hose - how high can it pump?
Washer is in basement with no drain. Can get to basement window and then to drain. Window about 3 feet above top of washer. Can it pump this high?
  • sunflower650 May 11, 2010
    Aborcass,
    Tina here we talked on Sat. I need more help from you. I changes my hose from up in the pvc pipe to the drain directley into the wall straight across from hose fitting on machine. But the I had the problem of the water just being drained out and never filling the machine at all. (siphone effect) So it wouldnt wash but It would high speed and completely drain the clothes(What I need know). So I cut the hose and put it back into the pvc pipe but now the water comes back in after finalspin and the final spin is slow its not like it was when the hose was hooked up on the bottom drain(but again the bottom drain hookup would not wash my clothes. Hope you can help. On unemployment and need to do the cheeap route. Thanks again Tina
    President:
  • Kenmore Master
  • 2,651 Answers
Sur thats a fine height, i wouldnt go past 8ft
Posted on Jan 26, 2009
Specs for drain pump model LXR6232EQ0
It wont pump that high, well it will BUT when the pump stops it will drain all the water back into the machine or it will give you an error that it is not able to drain fast enough. The only thing that might work it the installation of a check valve.
Jan 30, 2014 | Whirlpool Washing Machines
Maytag centennial washer - not draining on some settings
Check outlet hose for kinks or restrictions. Make sure the outlet hose is free to expel water at full volume. Make sure the outlet hose is not mounted to high. Check pump impellor has all it's vanes intact. Check for coins in all hoses & pump.
Dec 21, 2013 | Maytag Centennial 3.2 cu. ft. SuperSize...
Kenmore 90 series washer we want to put it in the basement- How high will it pump the water(no drainpipes in basement) and can I plumb it directly into our 2 inch gray water pipe or do I need to pump...
no higher than the manufacture drain hose can reach ...no donot plum directly to pipe !!! yes if must into a utility making sure pump hose goosneck and end of drain hose never gets submerged under water cause water to siphon back into washer....
Jan 28, 2011 | Washing Machines
At the end of a cycle, water has accumulated in the bottom of the machine and laundry comes out wet. The machine is in a basement and worked fine, but we decided to clean up the original installation...
Several possible causes of a top load washer not fully draining.
a.) Kinked or obstructed drain hose
b.) New drain outlet is too high and the pump is not powerful enough to fully drain the washer
c.) Failing pump motor, that does not fully drain the washer.
Ask more questions if this info does not help resolve the problem. We can solve this!
Jan 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
What is the vertical pumping capacity for a Maytag Neptune washer
I believe it can be done,but I dont think it is recommended by the manufacturer. if you are in a basement and that is your only option, the only suggestion I would have is to build a platform for the waher and dryer to sit on . It would have to be very sturdy. Maytag recommends that you install a wash tub or something of the sort and install a sump pump to pump the water into the drain.
Dec 17, 2009 | Washing Machines
How high can I pump up to a drain.
I have the same question....since I own a cabin with no basement floor drains. I have to pump my washer discharge to a main level drain.
To check the elevation needed, hook a garden hose to the discharge line and, after running the discharge end outside, raise or elevate the line using a line and tree branch to determine the height at which pump discharge quits. 33 feet equals appoximately 1 atmos or 14.7 psig.
Oct 05, 2009 | Roper Washing Machines
Washing machine weak pump
why are you PICKIKING UP !!!!!!!!!!!!!!!
Aug 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
How far will a washer pump up water?
Yes, it should pump it that far, but you may shorten the life of the motor by doing so.
Thats only adding about 4 foot since it already pumps it about 3 ft to the standard drain hight.
Jan 27, 2009 | Maytag Washing Machines
How high can the outlet hose from a Kenmore Series 90 washing maching pump. Location is in basement with not drain but could get to basement window and then to drain. Window approx. 3 feet from top of...
The pump should be able to move waste water 3 feet above the washing machine but if that fails, then you could always buy a sewage ejector set up ( plastic barrell with internal pump and water level sensor) . Those have a highjer pupm head pressure and would be able to move water up a column further than a washing machine pump. IN all probability, you will be ok at 7 - 9 feet from floor.
Hope that helps..
Regards
Rick
Jan 26, 2009 | Washing Machines
Cannot get to drain washer if the hose needs to go up into ceiling to get to septic pipes
usually the outlet and the pump is capable of pumping out at the maximum high of 3-4 feet from the drain. if any higher than that, you need to add a pump in line.
Oct 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
462 people viewed this question
Sal De
fordexpert
Robert Rankin
