Question about Music
Laney Tf-320 tube fusion guitar amplifier
Trying to find a user manual/ specs for this amplifier
3 Suggested Answers
arithebasspl
  • 3 Answers
SOURCE: My Laney VC30 Guitar valve amps volume keepd fading in
CHANGE THE TUBES. ARITHEBASSPLAYER
Posted on Mar 26, 2009
  • 5603 Answers
SOURCE: Hi,I just bought a Roland
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Posted on Apr 22, 2011
Am getting a bad buzzing noise from my laney lc15
Bad connection? Loose fittings? I used to get a crackle from my amp when I turned the volume or balance knobs. A quick spray of WD 40 down the shaft after removing the knobs fixed it.
Mar 13, 2016 | Laney LC15-110 Guitar Combo Amplifier (15...
Having some negative issues while playing guitar through my amplifier.....
Have you checked all the other amp tubes? You may have a bad 12AX7 or 12AT7 tube.
Aug 02, 2014 | Peavey ValveKing 100w All Tube 212 Combo...
My Laney VS30 212 at band practice last week decided to intermittently cut out, but not fully just the volume would drop out then return about 5 mins later. Not sure if this was a common problem. It might...
Sounds like output valve, if the amp is more than few hundred hours then suspect this for sure. I don't know much about this amp specifically but does the sound fade/return suddenly or over a few seconds? Try running it with the back off and fan on the valves etc. Then play at loudness where problem occurs and see if any improvement. Remember that at band practice you always play much louder than you think and put a lot of stress on it.
May 03, 2011 | Laney VC30-212 VC Series 30 Watt Class A...
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
Apr 22, 2011 | Roland FS1 Footswitch Pedal Switch
I get a hum whether the guitars plugged in or not...same problem with my GH100...happens at different locations...so that rules out outlet wiring...
A low hum may be perfectely normal in these, however if you can hear it four feet from the speaker that would be too loud.
Filter capacitors are always suspect, but an oscilloscope is the correct tool to diagnose the problem.
Mar 06, 2011 | Laney GH50L 50 Watt All Tube Guitar Head
It lights up but there's no sound what so ever... /Nicke
Hi, when ever an amplifier comes on and no sound with it,it means that you will need to replace the sound IC that controls the sound that comes out from the output.
When you replace it the amplifier will be fine.
Have a nice day.
Feb 22, 2011 | Laney GH50L 50 Watt All Tube Guitar Head
Bugera 1960A - channel 2 has very low volume even when vol2 knob is turned fully UP!
The user manual is located at: http://www.bugera-amps.com/PDF/Downloads/1960_P0671_M_EN.pdf on page 5; When the HIGH 1 and LOW 1 (or HIGH 2 and LOW 2) connectors are used simultaneously, their sensitivity is the same (both LOW). This may be your problem however--- Try swapping input chanels to see if the problem follows ther cable or is in the amp.
Assuming it was working before, you may have a short in the cable or a bad component or tube in the amp. Tubes can be difficult to come by. If the other channel works correctly, It may be one of the small tubes. Hope this helps
Jan 04, 2011 | Behringer Bugera 1960 Classic 150-Watt...
Mar 25, 2009 | Music
Music Logo
163 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
