Question about Hotpoint Wma32p Wma34p Wma36p Washing Machine Door Lock Interlock Switch
WMA36 washer going through wash cycle then stops can turn knob to rinse and spin and only sometimes it will then work. Otherwise it just keeps rinsing and not draining much and sometimes not spinning!
  • Hotpoint Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Posted on Jan 19, 2013
  • 1462 Answers
SOURCE: Machine stops in Rinse & Spin Cycle & leaks water
suspect problem is that water is not draining fast enough so when machine gets to spin there is too much water present which gets thrown up thro thew soap drawer. check the filter. on many hotpoint filter is not obvious. at back, take off bottom panel. you will see a large dia hose going from bottom of machine to pump. undo this hose at the tub end and the filter is inside it. be carefull. if you havn\'t managed to drain, a lot of water will come out. if this doesn\'t work, get back to me if you want
Posted on May 26, 2007
  • 183 Answers
SOURCE: washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Posted on Dec 25, 2007
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
  • 57 Answers
SOURCE: Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
Posted on Jul 15, 2008
  • 1294 Answers
SOURCE: washer won't finish cycle .
The error FH will stem from the drain pump operation and sometimes from the flow meter itself. The first thing to check is to drop the bottom panel and make sure the drain filter is clean. It sits right in front and just unscrews. Make sure to have enough towels on hand to soak up the water that is left in the tub. After you have checked this make sure both water valves are turned on, clear the error by pressing pause/cancel twice. Check to make sure the drain hose is not kinked and that there is no siphon problem.(Check your pump too now that you've opened up) If the error still returns after checking the above, the next thing to suspect is the flow meter itself. This sits right in line with the water inlet valves. It's just a reed valve that measures the amount of water entering the washer and monitors the pressure switch. You can access it by removing the top and it will be on the left side in line with the inlet valve. Look for holes in this tube, change if any.
Posted on Apr 01, 2009
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
I have a timer control problem with a LSR5233EQ0. I need to press down on the timer knob to keep the machine working. It will agitate but with stop when it goes to spin.
Possible that the timer contacts are not giving connectivity when it moves forward into the cycle and so there is no control to the motor drive causing it act irregularly.
The suspect seems to be the timer module.
Jul 29, 2012 | Washing Machines
When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
Hello
Try reseting the machine.Unplug power for 60 seconds.
Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
It is possible the control timer is going bad.
Aug 29, 2010 | GE Washing Machines
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Rise and spin
While the machine is operating take the timer knob and wiggle it around. If the machine cuts out momentarily then the timer is bad. If not then I would check out the lid switch to see if it is affecting the rinse and spin cycle.
Eric
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Open Questions:
See all Hotpoint Wma32p Wma34p Wma36p Washing Machine Door Questions
Hotpoint Wma32p Wma34p Wma36p Washing Machine Door Lock Interlock Switch Logo
62 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
