Apple iPhone Smartphone
Problem for Apple iPhone Smartphone
Re: IPhone doesn't connect with wifi automatically - password not recoginized HELP!!!
By dzineguy on Jul 15, 2007
My IPhone seems to connect to all WIFI spots EXCEPT my own.
I always seem to be on the Edge Network while at home. My laptop (Toshiba)has no problem connecting to the wireless network. I am using a Lynksys Wireless-G Broadband Router.
How can I repair this problem? I have looked at the Iphone Settings Category... The WI-FI shows (Not Connected), when I reference this icon I am asked to choose a Network. (My network shows a lock icon, whe I select my network I am asked for a password. I enter the password, hit the join icon and I am notified "Unable to join network" I need alot of help here.
Same Problem
Nov 28, 2008
-   same problem, i had been to apple store they upgraded from 2.1 to 2.2, wifi worked for the first day and from the next day i had similar issues "unable to connect to network". i have tried verything downgreading and reseting, no luck. i will go back to apple store again to change the phone. not sure if this is hardware or software related. during the process i have deleted all the apps. -   vixky
Nov 10, 2008
-   When I enter the password for my wifi network, either at work or at home, the message is that the iphone is unable to join the network. I don't know what to do to connect to any wifi network? -   fnovin
Nov 06, 2008
-   I have the same problem. What do you recommend?
-   cfpenry
Oct 16, 2008
-   Im unable to connect to wifi network. i need a password where do I get it>-   slimbronson
Aug 25, 2008
-   I too have the same problem. When ever I try to connect to my WiFi getting a message "Unable to join the networ"-   ebom
Best Solution
posted on Feb 02, 2009
Very Helpful)
Rushmore94
Rank: Apprentice
Rating: 97%, 6 votes
Had this problem for a couple of days now, and finally cracked it!
Bear with me through explanation, as I'm sure it'll solve your problem. With my router, I have WEP protection. The passkey (i.e. 7A533AA1C7) is generated by me inputting some text (in this case 'nickiscool') and the router converting it to hex or something. I then have four options of codes similar to the above (let's call them 1,2,3 & 4). I select one of these, apply the settings, and thats the passkey set.
Then, I go to my wireless settings on my PC, try to connect to the wifi and input the passkey. Crucially, beneath the passkey entry bit is a 'Key Index', this has to be set to the correct number (1,2,3 or 4) for the connection to work.
For example, I have chosen passkey 2, so I must set my key index is set to 2. Everything works and I'm all happy. That is until I try to find the wifi on my new iphone...
It finds the network, but every time I input the correct passkey, it says it's incorrect. Frustrating! But, what it seems to me is that the iphone's 'Key Index' is permanently set to 1. So, to fix...
- Go into your router settings, generate passkeys and pick option 1.
- Go into your wireless settings, input the new passkey and set 'Key Index' to 1 so your wireless keeps working.
- Attempt to connect with your iphone, use new passkey.
- Bet it works!
Best of luck with it. Tricky and annoying problem, but this seems to have fixed it for me, and I tested it a couple of times to make sure the theory is correct.
Cheers
Nick
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jul 19, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Following up on my post I came across http://www.jangro.com/a/2007/07/15/is-yo...
Solution #3
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a similar problem. For me I am using WEP so I turn this on under the iPhone security settings and then enter the password. Unfortunately it always says that the password is incorrect.
My plan is to temporarily disable WEP at home to see if the iPhone will connect with no security enabled. I haven't got around to trying this yet but perhaps it is something you could try also.
This would not be a real solution of course as I wouldn't want my home WIFI to be open but at least it would tell me if it is a moe fundamental issue or not that the password verification.
Solution #4
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Also take a look at http://docs.info.apple.com/article.html?...
I don't know if this is a factor or not but might be worth a go if the other solutions don't work
Solution #5
posted on May 13, 2009
Somewhat Helpful)
uerym
Rank: Master
Rating: 79%, 147 votes
FIND YOUR SOLUTION FROM APLLE.
HERE IS YOUR SOLUTION
www.apple.com/iphone/prob237ji32/solution
Thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #6
Somewhat Helpful)
eyumr
Rank: Master
Rating: 79%, 79 votes
Hi Friends,
Problem with Apple iPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock your iPhone now you must Click Here.
If you have any other problem with your iPhone you can try the site by Click Here. May the site can help you.
Was this helpful?
Yes
No
Solution #7
posted on Apr 06, 2009
Somewhat Helpful)
captainjesse
Rank: Apprentice
Rating: 75%, 2 votes
Just make sure the router is not set to wireless n. The iPhone will not work with wireless n only with wireless b/g. Try resetting your router to work with b and g only or with g only.
Was this helpful?
Yes
No
Solution #8
posted on Nov 23, 2009
Not Rated)
Itnumptydad
Rank: Apprentice
Rating: 0%, 0 votes
With reference to Solution #7 that is not true, I have wireless N and my i Phone (2 weeks old) works fine. My problem started when my old Netgear router died (or I killed it). I replaced the router and everything appeared to work except the i Phone. Yesterday I had all sorts of issues with a PC wirelessly connected. Someone suggested I changed the SSID name, which, given my numptiness, I thought was asking for trouble. However fortune favours the brave and I changed it. It still keep the same WEP key (I am not WPA yet) so all I had to do was re-enter the WEP key in the wireless devices which all picked up the newly named network.
Everything worked straight away, even the i Phone. My wife will be back soon and I am confident I can get her i Phone to work now. So if in doubt change the SSID is my recommendation.
Regards
Rob S
Was this helpful?
Yes
No
Popular Solutions for Apple iPhone Smartphone
Questions and Unsolved Problems for Apple iPhone Smartphone
Do you recommend Apple iPhone Smartphone?
Answer
Answer
My phone keeps saying no sim card. i have tired all of the suggested tips (ecept getting a new one... (More)
Answer
I got a brand new iPhone 3GS and when I put my Vodafone SIM card in it, it flashes a message saying... (More)
Answer
jag här apple 3gs men blotothfunkar inte
Answer
Voice Mail Unavailabe: Turn iPhone off an back on again - Resolved my issue!!
13 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Aug 24, 2008
SAME PROBLEN
Comment by ejessa, posted on Aug 07, 2008
i have same problem and unable to resolve it. Any help
Comment by goodun1, posted on Jul 30, 2008
PS - my hexadecimal WEP code for my Livebox wireless router had to be all uppercase with no spaces and any "o" are actually zeros, there are no "o" all "0"
I've got the ANSWER - in my case I had to get my wireless modem (a Livebox from Orange Home Broadband) into "pairing" mode again before trying to connect my iPhone. Pressing button number1 on back of teh Livebox does this - tried re-connecting and bingo. You will need to set up your acces passcode too once you've got wireless connectivity, 4 digits or more.....
Comment by goodun1, posted on Jul 29, 2008
Exactly the same issue:
Setings -> Wi-Fi -> choose a network -> (shows mine) -> select this one -> asks for password -> type in 26 character hexadecimal wep key provided with router (tried it with/without spaces, upper/lower case etc.) -> unable to join network -> only one option provided "dismiss"
All other (both) laptops/PC's attach no problem...
Comment by Guest, posted on Mar 16, 2008
don't have a password to unlock and connect to wi-fi network
Comment by Guest, posted on Mar 12, 2008
no wifi connection
Comment by Guest, posted on Nov 17, 2007
It says 'select a wi-Fi network, and the only option is D-Link, then to enter a password, after I've done that , it says 'Unable to join the network'.
No other options given. Any advice on what to do now would be welcome. Cannot make or receive a call.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iPhone Smartphone:
Top PDA Experts
Rank: Wiz Wiz
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
