Question about Ricoh Aficio MP3350
Call service SC 925 - Ricoh Aficio MP3350
Ricoh c6501 sp error coad sc 925 solution
SC925 B Net File function error *GW The NetFile file management on the HDD cannot be used, or a NetFile management file is corrupted and operation cannot continue. The HDDs are defective and they cannot be debugged or partitioned, so the Scan Router functions (delivery of received faxes, document capture, etc.), Web services, and other network functions cannot be used.
HDD status codes are displayed below the SC code: • Refer to the four procedures below (Recovery from SC 925). Here is a list of HDD status codes:
Display Meaning (-1) HDD not connected (-2) HDD not ready (-3) No label (-4) Partition type incorrect (-5) Error returned during label read or check (-6) Error returned during label read or check (-7) "filesystem" repair failed (-8) "filesystem" mount failed (-9) Drive does not answer command (-10) Internal kernel error (-11) Size of drive is too small (-12) Specified partition does not exist (-13) Device file does not exist
Procedure 1
If the machine shows SC codes for HDD errors (SC860 to SC865) with SC 925, do the recovery procedures for SC860 to SC865.
Procedure 2
  1. If the machine does not show one of the five HDD errors (SC860 to SC865), turn the machine power off and on.
  2. If this is not the solution for the problem, then initialize the NetFile partition on the HDD with SP5832-11 (HDD Formatting - Ridoc I/F).
    NetFiles: These are jobs printed from the document server using a PC and DeskTopBinder. Before you initialize the NetFile partition on the HDD, tell the customer:
    • Received faxes on the delivery server will be erased
    • All captured documents will be erased
    • DeskTopBinder/Print Job Manager/Desk Top Editor job history will be erased
    • Documents on the document server, and scanned documents, will not be erased.
    • The first time that the network gets access to the machine, the management information must be configured again (this will use a lot of time).
  3. Before you initialize the Netfile partition with SP5832-11, do these steps:
  4. Go into the User Tools mode and do "Delivery Settings" to print all received fax documents that are scheduled for delivery. Then erase them.
  5. In the User Tools mode, do Document Management> Batch Delete Transfer Documents.
  6. Do SP5832-11, then turn the machine power off and on.
Procedure 3
  1. If "Procedure 2" is not the solution for the problem, do SP5832-1 (HDD Formatting - All)
  2. Cycle the machine off/on.
Apr 12, 2016 | Ricoh Office Equipment & Supplies
Sc 925
CHECK THE THE HARD DISK
Jan 27, 2014 | Ricoh Aficio 1018D Copier
White 925
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 925) & click search
Jun 03, 2012 | Sewing Machines
How do I use voice dialing
Voice dialing with the Discovery 925 should be just as easy as pressing the "call control button" for a couple of seconds and it usually prompts your phone to ask for a command. However please keep in mind that the cell phone (and service) must be capable of voice dialing, also voice dialing and voice recognition on a cell phone are two totally different things. Sometimes those are misconstrued.
To view the Users Guide (Under Additional Information): Plantronics Discovery 925
Good Luck from Headsets Direct!
Jun 14, 2011 | Plantronics Discovery 925 Bluetooth...
My Sherwood R-925 tuner/amp turns off all the time can you help me ?
AUDIO gear usually does this when there is a major fault in the power amp section. Unless you are a qualified repair tech, you should have it repaired by a service tech.
Oct 07, 2010 | Sherwood R-925
Hello, ricoh aficio 1018d error code display sc 925 what can i do for it.
IMB non-connected error
Symptom:
IMB is not connected. This SC only
appears with B040 and B043 version
machines.
Possible Cause:
• IMB is not connected
• Poor connection between BiCU and
IMB
• IMB defective
• BiCU defective
Sep 27, 2010 | Ricoh Aficio 1018D Copier
Lost Coupler/Turnable
you can call at -  1-866-925-7278
or
follow the below link to order coupler -
http://www.partstore.com/Sitemap/LG+Electronics+Incorporated/Goldstar/Microwave+parts.aspx
Good Luck!!
Thanks
Nov 10, 2008 | Goldstar MA-1011 Microwave Oven
SCANNER SPEED IS SLOW
This company is based in the USA here are some numbers to get more info:
Technical Support: (925) 251-6399, Monday–Friday 7 a.m.– 4 p.m.
Technical Support for Out of Production Models:
(900) 776-5724, Monday–Friday 7a.m.– 4 p.m.
Order Department: (925) 251-6399
Customer Service: (925) 251-6399
Inside Sales: (925) 251-6399
Corporate and Government Sales: Click Here
Where to Buy: Click Here
Visioneer Corporate Headquarters:
5673 Gibraltar Drive, Suite 150
Pleasanton, CA 94588
Dec 04, 2007 | Visioneer Strobe XP 200 Path-Through...
Ricoh Aficio MP3350 Logo
95 people viewed this question
Top Ricoh Computers & Internet Experts
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
