Question about Miele Washing Machines
Miele w 819 red warning light - Miele Washing Machines
3 Suggested Answers
SOURCE: Miele S716 Not running red
Dry joint found on motor control circuit board.
Posted on Jul 18, 2008
SOURCE: I have a Miele turbo plus solaris and the red warn...
I had this problem with a different model. It's caused by a thermal cutout switch in the motor. My problem was a result of a filter being removed and the bag not seated correctly, hence dirt got into the motor and clogged the turbine, reducing airflow through the motor and causing the over heating.
If your motor runs at all, you probably have a blockage. Replace the filter inside the bag compartment just before the motor vent. Check the hose isn't blocked. Check the exit air filter.
If your turbine is clogged, it's a big disassembly job best done by a professional. If you really want to know how to cure it and feel you can tackle it yourself, email me. alan_at_alanjohnston_dot_com.
If your motor doesn't run at all and the light just quietly comes on, you have a break somewhere in the thermal protection circuit, either in the wiring (unlikely) or inside the circuitry buried inside the motor itself. I had an open on the thermal switch where the combination of heat and vibration deoldered the thermal switch from its board.
Hope this helps.
Alan
Posted on Aug 06, 2010
The red filter light will not reset after replacing the filter on my Miele S5980
Hi There, I actually did a repair on this problem only a couple of weeks ago. The problem could be that the small lever that pushes on the reset button on the circuit board is bent or broken. The little button costs about $10 from memory and certainly a whole lot cheaper than the board itself which is $234. Just to clarify in my case there was nothing wrong with the board, I was able to manually push the reset switch on the board and replace the tiny lever and problem was solved.
Apr 17, 2013 | Miele S5980 Capricorn /SEB 217
Will not start, will not reset
I have a Silver Moon S558, when I turn it on the power light comes on and a few secords later the red warning light comes on. What is causing the vacuum not to work? One day I was vacuuming, turned it off and a few minutes later went to turn it on and nothing, but these lights turning on. Is there a fix?
Mar 11, 2011 | Miele s558 Silver Moon Vacuum
Warning light on, vacuum will not turn on
Your machine is clogged ... probably in the hose.
ASSURE the air path is clear and the filters are clean before yhou proceed.
Let me know how you make out on this.
a
Sep 23, 2009 | Miele S558 Red Velvet Bagged Canister...
Our vacuum (a miele S718) has cut out.
Probably WAY too late to help you now, but may be of assistance to others (I repair appliances): Several times, I've had Miele Vacs which show the red light, but the motor never powers up. If the vac was working perfectly before, 98% it will be a bad solder joint on the Motor pcb. Although it varies per vac: Remove the bag & 4 screws around.
Unclip & remove lid (flex off pivots), then remove centre screw. Lift off control panel. Remove all other screws under the control panel area.
Lift out motor & unscrew motor pcb. Turn over & inspect for any black joints - repair as ness. Reassemble in reverse order - note: difficult to locate top cover back on if lid wasn't removed, as lid power connection can interfere. Hope this helps...
Jan 31, 2009 | Miele Red Star Bagged Canister Vacuum
Ls400 indicator lights coming on
you need a new alternator
Nov 03, 2008 | 1991 Lexus LS 400
Stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Dec 05, 2007 | Miele CatAndDog700 Bagged Canister Vacuum
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
