Question about Crosley Kitchen Ranges
Maytag Maytag CFE8010ACB selector switch - Crosley Kitchen Ranges
  • Bryan Howell Jan 22, 2013
    Anyone have a wiring diagram for a Maytag CFE8010ACB?
    Top Expert:
  • Crosley Master
  • 9,472 Answers
That part is no longer available.
Posted on Jan 19, 2013
    Hi Richard, I am aware the part is no longer available. I am looking for an alternative but could also use a wiring diagram for this oven: CFE8010ACB
Can't change dispenser selector
seems defective control panel in front of fridge
Dec 06, 2013 | Maytag MZD2667HE Side by Side Refrigerator
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Model GSD3620Z02BB - The normal cycle will not engage when the knob is turned. The short cycle will engage (sound like it is working) but the soap is left in the reservoir and about 2 inches of water is...
Sounds like the selector switch has gone bad. The machine is not fully cycling thru and draining because the selector isn't proceeding like it should.
This typically happens if the selector dial is spun real hard repeatedly over time. The little cogs inside of the selector will get broken and sometimes the broken parts will lodge inside the switch and cause jams.
May 27, 2011 | Maytag Dishwasher
Fan does not run on high speed .
dear sir
if you how know to read a electric tester then check you air con,s selector switch please find out the fan motor wire in selector switch and test one by one and turn to fan on high speed mode and check on selector switch there electric supply comes on selector switch if it,s come and motor doesn't work then it,s mean motor high speed is defective if supply not come on selector switch then it,s mean selector swith is faulty .
if you can check like this then do if not then contact to a technician,
thank you
hope answer the question
please vote1
Sep 30, 2010 | Maytag Heating & Cooling
Maytag dryer won't turn-on.
Howdy: The on/off switch sends a pulse to the ignitor, then to the element. If the motor popped it's breaker then nothing happens. But it still could be just the on/off selector switch. Good luck - Doug
Dec 09, 2009 | Maytag Dryers
The washer will not fill when the temperature is set to cold. However, the washer will fill if the timer is advanced to rinse (which is always cold). This occurs for both regular and delicate cycles. Is...
It's going to be your timer. It has points inside. The point the sends power to your selector switch at the beginning of the cycle is burned.
Please ate solution
Sep 08, 2009 | Maytag Washing Machines
Maytag Front Load Washer - SD error
hi there,
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
thanks.
Sep 26, 2008 | Maytag Neptune MAH6700A Front Load Washer
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washing machine wont work on certain settings
the selector switch for loads is just a switch that connects parts of the timed cycle to the timer circuit. if the timer is not rotating then nothing will work. check the connections through the selector switch. burnt or melted contacts within the switch calls for a new switch. try repair clinic dot com for a replacement.
Apr 19, 2007 | Maytag Dependable Care LAT9706
Kitchen Ranges Logo
46 people viewed this question
Top Crosley Kitchen Ranges Experts
Rob
Rob
Level 1 Expert
freddyfox
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
