Used to click on my You Tube videos , click play, click Share facebook , type friend name and it would post on there wall automaticly now does not give me that option , posts to my facebook wall only ??
SOURCE: Company Share Drive access error.
is the drive mapped if so you may need to attach the drive again look under mapped drives and if it dont show there then click on tools map drive select the appropate drive letter and path you can look on another machine just click on my computer tools map drive get the info write down and type it or click over to it select it and bam your back....
SOURCE: about connectiong two pc.
What you're describing is known as a simple home network. The easiest way to do this is by using a gateway router or modem that has the capacity to broadcast a wireless signal (for your laptop) and uses an ethernet connection for your desktop. (Or you can connect both machines to ethernet cables that are routed through your house to the respective locations). Please see this article, for general info on the subject. And for details on setting up the network, please see links here and here.
After both computers are set up on the network, you can establish files and printer sharing for each, and assign shared properties to particular files that you wish to make accessible. (see link above).
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: How to use password instead of fingerprint to logon
How to disable fingerprint reader
In Windows, in the settings section of the Fingerprint Control Center, uncheck Replace windows logon with fingerprint protected logon. In the Fingerprint section uncheck the Power-On Security section if the user has fingerprints enrolled there. You do not need to uninstall the software unless you wish to.
SOURCE: unable to watch family video posted on facebook on my computer
Update your Adobe flash player software to the latest version:
http://get.adobe.com/flashplayer/
If that doesn't fix it you might have some viruses and malware.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs...
Share Your Photos With
Friends via Yahoo Messenger
1.Click on an album you want to share in the collections list.
2. Click "Edit" in the taskbar. Choose
"Album," then click "Instant Message."
3. Select a friend to share your album with from the friends
list when the Messenger window opens.
4.Both you and your friend will be able to view the album slideshow in the Messenger window.
