Question about Polk Audio Audio Players & Recorders
On the bac of the subwoofer it has speaker level output and input ,how come i cant get no sound out of them when i hook up the other speakers
  • 356 Answers
You may have the speaker/subwoofer cables reversed.
Posted on Jan 20, 2013
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Posted on Jan 07, 2009
    mlapres
    • 757 Answers
    SOURCE: Hooking up my Digital audio subwoofers
    How did you connect it to your receiver?
    Posted on Jun 19, 2009
    dunnbiker
    • 8546 Answers
    SOURCE: Which is the best way to hook up a Subwoofer?
    Last two questions first - YES, use an RCA splitter to share sub line level out between two subs and use one at the subwoofer end to share that line with both inputs on the sub.
    Either attachment scheme you describe would work.
    Not being a big fan of conversion/deconversion for no real purpose, I would avoid stepping the high-level input down to line level for use by the sub's internal amp, run RCA to the sub(s) and keep them physically and electrically independent of anything else unless cable routing is facilitated somehow by daisy-chaining other speakers from the sub(s).
    Posted on Jan 19, 2010
    Testimonial: "Thank you very much! I live in the "boonies" and it fascinates me that I can get an expert opinion online. I appreciate it."
    • 547 Answers
    SOURCE: How do i use the high level speaker inputs on this snell QBx sub.
    Most likely, you simply connect the speaker wires to the high level inputs, along with the cable from your amp.
    Given that Snell's are high-end speakers, I would recommend that you contact their tech support for your question. They have a specific email address for technical questions on their Support Page.
    Posted on Jan 23, 2010
    dunnbiker
    • 8546 Answers
    SOURCE: hook up lower level input
    The speaker level connectors on the sub are for use when you DON'T have an AV receiver-style subwoofer output. They only pass-through from YOUR amp to other speakers. You should NOT use both Line level and Speaker Level input to the sub.
    What is your electronics? Have you looked at the manuals?
    Posted on May 03, 2011
    I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
    The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
    Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
    I hope that works for you.
    Feb 15, 2015 | Sony STR-DE597 Receiver
    How do I hook up a powered subwoofer to a pioneer sx-316?
    Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
    Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
    Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
    Apr 06, 2014 | Audio Players & Recorders
    How do i connect a sub wooferto my reciever
    I own 2 of these Pioneer VSX-D903S units.
    The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
    If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
    Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
    Jul 20, 2012 | Pioneer VSX-D903S Receiver
    Hook up lower level input to the audio source 230 subwoofer but can't get any sound for the speaker that is hook up through the speaker level input or output.
    May 02, 2011 | AudioSource System 230 / 235 System
    How do u hook up the infinity entra sub it has speaker level(input and output) that look like these red and black spots r for spearker wires and then line level input so I connect my music to the rca plugs...
    Maybe if you described the setup with exact model numbers for everything involved we might be able to answer with specifics.
    You could poke around her for the Entra Manual for YOUR model.
    http://manuals.harman.com/INF/Hom/Owner's%20Manual/
    What they do NOT explicitly tell you is that the amp in the sub is not for your other speakers running off it's Speaker Level outputs. They're just there as a pass-through if you use Speaker Level from your own amp.
    Line Level (RCA) IN to the sub will NOT pass anything out those Speaker level outputs.
    Jan 13, 2011 | Infinity Entra Sub Subwoofer
    When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
    I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
    If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
    I hope this helps - and good luck!
    Nov 24, 2010 | Cerwin Vega AVS-632 System
    Jan 17, 2010 | KLH PSW8100-8 Subwoofer
    Connect powered subwoofer
  • Nov 22, 2008 | Audio Players & Recorders
    Subwoofer to receiver hookup
    In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
    Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
    john
    Aug 18, 2008 | Audio Players & Recorders
    238 people viewed this question
    Top Polk Audio Audio Players & Recorders Experts
     Grubhead
    Grubhead
    kdigby
    kdigby
    Level 1 Expert
    Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
