Question about Microsoft Xbox 360 Controller
I have an xbox wired controller connected to my pc and on some games (Dark Souls, I Am Alive) if the camera is behind the game character he will not run but if i move the camera to the side he will run i'm not sure what the problem is, any ideas?
hockeyguyJC
  • 133 Answers
SOURCE: I can't find xbox 360 driver for my PC
The latest driver can be found here:
http://www.microsoft.com/hardware/download/download.aspx?category=Gaming
Posted on Aug 25, 2008
SOURCE: XBOX 360 Wireless Controller PC Connection Problem
WARNING: try at your own risk!
I kind of fixed it. The problem appears to be with the USB controller - specifically, my mouse (a Razer Copperhead) and the XBOX 360 wireless receiver. A lot of work went into the solution, but I essentially ended up uninstalling and unplugging all of my USB devices (you can uninstall them using device manager in System Properties>>Hardware within Control Panel. Look for Universal Serial Bus and uninstall everything in that category). Reboot. Then, I first plugged in the device in question (my 360 receiver). Afterwards, I one by one plugged in each item until I found the one conflicting with the receiver (my mouse). After that, I uninstalled all devices again and next uninstalled the drivers for the conflicting device (my mouse in this case) and rebooted again. After this, I tried several times to uninstall and reinstall the mouse and various USB devices until finally it worked (sort of).
I call this a partial solution because now I appear to have the opposite problem. My mouse seems to be conflicting with another device (probably the 360 receiver). My mouse refresh rate is very choppy. The good news (for me) is that I can uninstall the USB controller for the mouse, reboot, and both the 360 controller and the mouse will work fine... that is until shut down. Then I have to uninstall the mouse controller and reboot again. Needless to say, I keep my computer on more than usual now.
Posted on Dec 01, 2008
SOURCE: Can't Connect Wireless Controller to PC
You cannot connect it unless you buy the M$ wireless dongle for your pc.
Posted on Sep 24, 2008
SOURCE: Wired X Box 360 Madcatz 4716
http://www.madcatz.com/faq/?Action=Q&ID=89
do it
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: xbox 360 wireless contoller won't sync with game console
If you're using an HDMI connection between the Xbox 360 and the TV, it might be that. When using HDMI, the Xbox won't boot up until it knows what the TV is capable of displaying. Although the controller will turn the console on, it won't sync with the console -- and it's not a controller or console problem, but just a symptom of the fact that the Xbox won't get to the point where controllers will sync until it can properly communicate with the TV. I'd recommend turning off the TV and the Xbox, disconnecting the HDMI cable and re-connecting it after making sure the contacts are clean. Then turn the Xbox back on first; you'll likely to see the same behavior. Finally, turn the TV back on. With it being switched back into HDMI mode, it just might "kick-start" the Xbox into a good communication link across HDMI. Hope that helps.
Posted on Feb 23, 2009
Dark souls walkthrough
Check the Dark souls wiki page.
Nov 06, 2013 | Sony Playstation 3 (PS3) Console
Mx vs atv alive says activate second controller
I guess it's as easy as pressing A or Start.
But if the controller really isn't connected anyways, you have to:
1: Turn on controller, and hold the sync button ( just to the right of the Left Bumper ).
2: Press the Sync button on the Xbox 360
> Slim version: Sync button is placed just beside the usbports on the front of the xbox.
> Original version: The sync button is placed just beside Memory Slot B ( looks pretty much as the one on the xbox controller.
3: The controller should connect and sync automaticly to your Xbox 360.
Jan 10, 2013 | THQ MX vs ATV Alive for Xbox 360
My controller keeps making me head backwards
Sounds like a calibration issue. It can also be a hardware problem in which case you will be better off buying a new controller. You haven't clearly mentioned exactly what brand your controller is. Is it Logitech or Microsoft brand? It is for PC or XBOX?
If its Microsoft brand and for PC you can try calibrating it from Control Panel -> Game Controllers -> XNA Gamepad -> Properties -> Settings -> Calibrate.
Nov 16, 2012 | Microsoft Logitech Wireless Black...
In game characters move automatically
This movement is because of a joystick that is broken. The joystick, while in the netural position, is sending signals to the console and thus moving the character. The only solution is to pull the joystick straight out until you hear a click. If that does not fix it, then the controller is broken.
Apr 24, 2011 | Microsoft Xbox 360 Controller
Controller
Sounds like you went to a lot of trouble to play this game. Since you used all different hardware, I would think it would be one of two things. 1) Were the controllers you used official or off-brand? Some off-brand controllers don't work 100% with all games. 2) Check the surface of the disk for scratches or warping. Also, on the off chance that the controller you were using are wireless, try a wired controller as some wireless can be easily goofed with due to radio interference. On a side note, I am guessing you meant European Assault, if you are playing the European version of the game, then that would cause you even more problems.
Aug 31, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Controller Logo
230 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
