My 900gb usb having exfat format however its speed too slow , NTFS does not apply and format complte , help pls how can i make it normal
  • 736 Answers
SOURCE: I need to format the USB I have to a Fat
normally you would format to fat32 that will be compatable with most systems ..... exfat is used only for linux ... but linux can also use fat32 and NTFS .... microsoft can't read exfat without a special program ... you can use NTFS if you hve a very large USB drive ...but fat32 will be compatable with the most systems ...
Posted on Apr 03, 2010
SOURCE: i want 2 run exfat pendrive in windows xp
First, your Windows XP must be either SP2 or SP3, and then you must add a patch to it. http://support.microsoft.com/kb/955704/en-us that is KB955794 for the patch
Posted on Jun 12, 2010
SOURCE: Hello I bought transcend external
I can not format a transcend external hard disk.Please Solution it problem.
Posted on Nov 24, 2010
sodeep
  • 3267 Answers
SOURCE: I have a 500gb kingston
connect to a PC and use windows format command to format in NTFS format,
Posted on Jun 26, 2011
clairexiang1
  • 59 Answers
SOURCE: How do I format my
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Posted on Jan 17, 2013
Formatting from RAW to exFAT does not work. computer (Toshiba satellite W7) says unsuccessful
How to Format Hard Drive With Windows 8 eHow
Step 1:
Back up all data on the drive you want to format. Tap the "Search" icon on the Windows Start screen and type "format disk" in the Search field. Select "Create and Format Hard Disk Partitions." The Disk Management utility opens.
dff89d62-f4c0-4d6e-b10c-7cba410b4b66.pngSelect "Create and Format Hard Disk Partitions." (Image courtesy of Microsoft.)
Step 2:
Click the drive that you want to format. Note that in most cases "Disk 0" is the drive with the Windows operating system on it. If this is the disk you want to format, you should reinstall Windows instead.
2fe0d696-372b-421f-b49f-da062aabbeec.pngSelect the drive you want formatted. (Image courtesy of Microsoft.)
Sponsored Links
Step 3:
Click the "Action Menu," select "All Tasks," and then click "Delete Volume..." Double-check that you have the right drive selected. The selected drive is shaded with diagonal stripes.
531c247a-9340-42a7-a785-35c37c5490ba.pngSelect "Delete Volume." (Image courtesy of Microsoft.)
Step 4:
Click "Yes" at the warning that all data on the partition will be deleted. After a few seconds, the volume is deleted. The drive is now listed as unallocated in the Disk Management window.
d35f80cd-51ea-4d05-8911-98dcebc0c93d.pngDisk Management warns that all data on the partition will be lost. (Image courtesy of Microsoft.)
Step 1:
Select the drive you are formatting if it isn\'t already selected. Click the "Action" menu, then "All Tasks" and "New Simple Volume." The New Simple Volume Wizard opens. Note that if the disk is part of an array, advanced users will have additional options like creating a new spanned volume, striped volume, mirrored volume or RAID-5 volume.
94a33b72-44e6-461e-9920-f69735d78d0a.pngCreate a New Simple Volume (Image courtesy of Microsoft.)
Step 2:
Click the "Next" button in the New Simple Volume Wizard so you can specify your preferences.
2b3d2635-9525-4ee5-a259-c38b5ba47fbf.pngThe New Simple Volume Wizard opens. (Image courtesy of Microsoft.)
Step 3:
Specify how much space should be used in the new volume by entering a value in the text field. If you are creating only one volume or partition in the drive, this number should be the same as the maximum disk space displayed above. Click "Next."
40a2b160-a7c4-4669-9f7b-9acdec319786.pngSpecify the volume size. (Image courtesy of Microsoft.)
Step 4:
Select a drive letter that you would prefer the computer to use for this drive. If you don\'t want a letter assigned, click the "Do Not Assign a Drive Letter or Drive Path" option. Advanced users may also prefer to mount the drive in an empty NTFS folder. Click "Next."
a7adfda9-4b8d-4ac9-8d3f-f9ffd7313665.pngSpecify a drive letter. (Image courtesy of Microsoft.)
Step 5:
Select a file system for the volume. Your options are ExFAT or NTFS. Use ExFAT if you\'re going to share files with a Mac computer; otherwise, NTFS is the better choice. Unlike its predecessors, ExFAT can support the same volume sizes as NTFS -- up to 256TB. However, it\'s not as robust as NTFS and doesn\'t support file system-level encryption and built-in compression. Mac computer\'s can\'t write files to an NTFS drive.
9a87dfc0-3bf5-43bc-9c8b-f51801f8795b.pngSelect a file system. (Image courtesy of Microsoft.)
Step 6:
Select the "Perform a Quick Format" option if the drive doesn\'t contain any private information, or if you\'re using the drive for your personal use. A Quick Format takes only a few seconds, but the data it leaves behind can be easily recovered by anyone with the right software. A full format takes much longer but it does erase every byte of data. Select the "Enable File and Folder Compression" option if desired. Type a name for the volume and click "Next."
3e35ad5c-5391-4201-a130-a49a67a41fd4.pngChange the volume label if desired. (Image courtesy of Microsoft.)
Step 7:
Click "Finish" after reviewing the settings that were applied to the new volume. If you want to change anything, click the "Back" button and format the drive again.
777198bd-fcb2-4516-b752-36d350d7ca61.pngClose the New Simple Volume Wizard by clicking "Finish." (Image courtesy of Microsoft.)
Step 8:
Select another drive or volume to format, or exit the Disk Management utility.
Read more : http://www.ehow.com/how_6026_format-hard-drive.html
Tips & Warnings
  • If you\'re formatting a drive to give to someone else, or if you\'re disposing of a drive that has sensitive information on it, you should always deselect the Quick Format option so Windows can perform a full format. However, even a full format may not make the data completely unrecoverable. The only way to be 100 percent certain that data can\'t be recovered is to destroy the drive.
References:
Microsoft Windows: Create and Format a Hard Disk Partition
Jan 09, 2015 | Western Digital WDBPCK5000ABK - 500 GB USB...
How to remove write protection from sony hd-e1
PC & MAC use different file systems.
It sounds like your hard disk is formatted as NTFS. NTFS will allow a MAC to read from the disk, but not write to it. You need to re-format it using FAT32 (if your MAC is older) or exFAT(if your MAC is fairly new)..
FAT32 will allow a maximum partition size of 2TB(when formatted from a MAC) and a maximum single file size of 4GB.
exFAT will allow pretty much any file size.
NB:Formatting a hard drive DELETES ALL FILES on the hard drive, so backup whatever is important before you re-format it.
1. Open Applications > Utilities
2. Choose you hard drive from the list on the left
3. Choose the "Erase" tab and choose your desired format (FAT32/exFAT)
4. Type in a new name..Click "Erase"
Apr 10, 2014 | Sony HD-E1 1 TB 2.5" External Hard Drive -...
Sd card full
try formatting to FAT32 or NTFS
Nov 15, 2013 | Wildgame Innovations Micro Red 8 W8E...
External hard drive cant format into ntfs but only exfat
The propriety NTFS file format is used by the Windows operating system to format internal as well as external hard drives. You can format an external hard drive with the NTFS format using the built-in program included with the Windows operating system. The procedure is straightforward and does not require any additional software. An NTFS-formatted external hard drive can then be used with any PC running a version of Windows that is later than Windows 3.
Plug the cable attached to the external hard drive into a USB port on the PC. Right-click on the "My Computer" icon on the desktop. Select "Manage" from the drop-down menu. Click on "Device Manager" in the left column of the window that appears. Click on the "+" icon next to "Disk drives" that is in the column to the right of "Device Manager." Right-click on the icon of the external hard drive. Select "Properties" from the pop-up window. Click the "Polices" tab at the top of the window that has replaced the pop-up window. Click the "Optimize for performance" button below "Policies." Click "OK" to close the window. Right-click on the icon of the external hard drive in the center column of the window that is still open. Select "Format" from the pop-up menu. Select "NTFS from the "File system" drop-down menu in the new window that appears. Click the "Start" button at the bottom of the window. Wait as a progress bar appears at the bottom of the window and fills in from left to right. Click the red "X" at the right corner of the window once the progress bar has completely filled in. format usb memory stick to ntfs http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
Overview and history of ntfs format http://www.pcguide.com/ref/hdd/file/ntfs/over-c.html
Apr 02, 2013 | Maxtor OneTouch III Mini Edition 120GB...
How format a HD to FAT32 if the options are only NTFS and exFAT?
Open a command prompt. Start, Run, type cmd <enter>
If the drive you want to format is F: for example type
format F: /FS:FAT32
Nov 26, 2012 | Belkin N1 Vision Router
When I connect my Iomega Ego Portable Hard Drive to my Iomega ScreenPlay TV link Director Edition, I can see the files, but I can't play anyone of them: the ScreenPlay TV waits for minutes (trying to...
try to change the format of the portable hard drive, i believe you have it under ExFat, and a usb is Fat32 these options are under any windows platform, connect your device, right click and select FORMAT, here change it from ExFat to either Fat32 or NTFS, the difference between the 2 is simple, Fat32 is more compatible to devices, like car stereos, tvs, etc, but it has a limit of uploading a single file up to 3gb were NTFS doesn't have a limit but not many devices support it. Formatting your drive to another one requieres all media to be deleted, and when your formatting, never forget to select "QUICK FORMAT"
hope this helps!!
Aug 18, 2017 | Iomega ScreenPlay TV Link Ultra-Compact...
I can't access my harddrive it keeps on saying error
Easiest way to do this go into windows control panel
Administrator tools
Computer management
disk management
You should be able to see the drive there
delete the partition then create the new partition under ntfs
Then format the hard drive and you should have a usable storage device now
Hope this helps
May 31, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
I need to format the USB I have to a Fat the only options I have are Fat32 NFST and exFat
Apr 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
