Question about Sony XS-GT6936X Coaxial Car Speaker
Sony XS-GT - Burrrrrrrr Noise
One of the Speakers in my car gives a Burrrrrr noise when there is Bass. How this could be repaired?
  • 156 Answers
It's likely that the cone is damaged, which isn't repairable. However, another problem I've seen with Sony speakers comes when the tweeter pod becomes loose on its mount. To check this, look at the bottom of the speaker magnet. In the center of the back plate, there should be a small screw. It might be hiding under a sticker. Try tightening the screw, if possible.
Posted on Jul 15, 2007
Jensen XS 10 w speaker in my bass cabinet vibrates.
You can not use a car sub in ,A guitar amp, that why it is doing that, i don,t belive some of the brainstorms you people come up with on this site,
Dec 02, 2012 | Jensen XS-1010 Car Subwoofer
Buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
Nov 03, 2011 | Logitech Z-4 Computer Speakers
Noise/No Bass in Delco Systems stereo
You have a possible fault in your wiring of the speakers, the Phases of the speakers are crossed over resulting in cancelling of the low frequency- bass frequency. Hence please reconnect the speakers front and rear with the positive/ negative to the corresponding positive and negative of the speakers.If you are unable to fix the marking of the polarity use 1.5 Volt cell to connect to the speakers , if the speaker moves up the terminal on the positve of battery is positive. reconnect and test with a good bass song for result. Helpful. Good day
Jul 05, 2010 | Car Audio & Video
2 sony XS-L102P5 subs, sound great with deep bass but cones chatter when I hit them real hard
There is a possibility that you may be overpowering or under-powering your speakers with the amp you are currently using or are playing notes below the specified range of "Hz" of the subwoofer causing the sub to sound distorted or as you would call it "chattering".
If the speakers range is 130hz-45hz and your playing notes at 30hz and dont have it tuned at the crossover either on the amp or the stereo to suit the subwoofer, the speaker will try and play the note regardless and will cause the cones to move beyond its range and may cause it to slap the magnet which can damage the subwoofer if consistently played that way. Please let me know if this solved your problem..
Nov 15, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
HI there, I'm installing the sony explode deck in my car to an amp, and then two speakers, I can't seem to get anything but bass....frustrated...
Its your settings on the amp. There is a noise filter to set it for bass or for high. Just move the switch. If it is set right turn the lph and vph the opposite way the it currently sits. That should fix your problem. If it doesn't check your stereo. If you have it ran through av cables to the back of the system it most likely has a bass filter built in. You have to get the high input wire clip and run it that way.
Jul 08, 2009 | Sony Xplod CD Player w/MP3 Playback...
I have the Sony XS-L120B5D subwoofer with enclosure: sensitivity-89db RMS-600 watts Peak-2000 watts impedance-4 ohm frequency rangh-20hz-2000hz its hooked up to an Arc Audio ks 300.2 amp: class-g/h power...
Do you have the crossover switched to "low pass"? and the frequency control below 80hz? Do you have the manual? If you need more help, post a comment and I can walk you thru it. Hope this helps
Jun 24, 2009 | Sony XS-L120B5D Dual 12" Ported Enclosure
trying to push to much bass here try this turn the head unit half way up and then go back to amp and turn the level nob all the way down and then turn it up to u hear it start to cut out let me no if that helps please rate if u have any more q and a's let me no
Sep 26, 2008 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Noise from speakers when playing basses
hello, check and see if cabinet has loose screws or if back panel is tight,bass can vibrate screw loose.good luck! also look for anything caught in the woofer causing the noise.
Jul 28, 2008 | Audio Players & Recorders
Sony XS-V1342A Coaxial Car Speaker
You amp has a low pass filter turned on. There should be a switch to turn it off on the amp, otherwise you need a different amp. Be careful, 600 watts is WAY over the v1342a's rated power of 45 watts rms. If you turn it up too loud, that amp will easily blow your speakers.
Apr 25, 2008 | Sony XS-V1342A Coaxial Car Speaker
Enclosure type
Sealed box and somewhat large if they are 12's I usually try to get 3 cubic feet overall internal dimensions and generally the inside dimensions will be 13" tall 32" wide and 13"-14" inches deep. with no divider and make sure the box is sealed. Personally I like to phase the speakers backwards. Gives the bass a little more rumble.
Jan 05, 2007 | Sony XS-L1200B Car Subwoofer
Sony XS-GT6936X Coaxial Car Speaker Logo
119 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
