Question about Whirlpool LXR9445JT Top Load Washer
Whirlpool top-loader LSQ9200LQ0
How do you remove the clothes mover of the Whirlpool Top-loader Washer LSQ9200LQ0?
  • 28 Answers
Im no expert, just pretty handy with all things mechanical...hope this helps:
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LSQ9200LQ0/Whirlpool-Parts-82574.cfm
Posted on Jan 26, 2009
Whirlpool F65 6th sense Whitemagic top loader fully automatic - Cloth Mover (Agitator top assembly) slipping - India Model.
HOPE PICS HELP U MAY HAVE BAD AGITATOR COUPLER, BAD CAM DOGS, ETC
SEE PICS
In your case the cam dogs are repalced with this coupler.
Jun 06, 2015 | Whirlpool Washing Machines
After the spin cycle the washer has a hard time stopping making alot of noise
remove the clothes mover/agitator and then remove the spanner nut located on top of the agitator and get the new drive block as this has worn out due to age their about $20.00
Sep 13, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Is the fabric softener dispenser at the top of the agitator replaceable?
Yes it is,although the whole peice running half way down will probably have to be purchased..It's called the(Clothes Mover)it has finns running down & can be removed by a bolt down the centre after removing the top cap.
May 21, 2010 | Whirlpool LSR5132PQ Top Load Washer
Agitator only works on bottom half. can I repair
if the clothes mover section on top quit,remove the detergent cup and with a 9/16" socket remove the bolt down inside,this will let you remove the clothes mover part,then you need to order the thrust bearing and dogs cam rebuild kit for this model
Mar 23, 2010 | Kenmore 22422 Top Load Washer
Problem for Whirlpool LXR9445JT Top Load Washer Whirlpool top-loader LSQ9200LQ0 The top half og the agitator is not turning.
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. For the model number you have listed, the part number for the kit is 285811 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Dec 14, 2009 | Whirlpool LXR9445JT Top Load Washer
Washer had filled and agitated, but when went to spin produced a loud screeching noise. what might it be? this is an inglis front loader super capacity 2001.
It may be a a worn or broken drive belt.
OR
Some Whirlpool brands washing machines have a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index. If the bearing or cams become stripped or damaged, the mover will often not work and the cam parts will have to be replaced.
OR
It may be a bad motor.
Hope this helps.
Aug 14, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool washer does not agitate/wash but the spin cycle seems to work. I've found that the bottom section of the agitator blades are turning but the top section does not turn. I can also turn the top...
The problem that your washing machine is not agitating, you will need to check certain things.
Please check the timer to see if it is in good working order or not. Next you will need to check the motor and the motor switch. On some of the newer washers the door switch also controls the motor.
If the motor starts running after the washer has filled to the selected level, but the agitator doesn’t move, you will need to check the following parts.
The agitator dogs. They are located inside of the agitator clothes mover. You will need to remove them and check to see if they are in need of been replace.
The clothes mover. This part is the top part of the dual action agitator. Its job is to move the clothes from the top of the spin drum to the bottom part of the agitator.
You will also have to check the inside of the clothes mover to make sure that the gear like cuts are not worn out.
However another problem could be a broken motor coupler.
Thank you for contacting Fixya.com
Aug 09, 2009 | Whirlpool Washing Machines
Suds indication
Hi!
For a top loader, a general rule of thumb is to lay clothes loosely inside the washer until they reach the top of the agitator. For a front loader, fill it until it's full, with minimal compression of the clothes.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Whirlpool LXR9445JT Top Load Washer Logo
1,700 people viewed this question
Dan Webster
Dan Webster
Sal De
