Question about CIPHERLAB 1000 Handheld Barcode Scanner
CIPHERLAB 1000 Driver - CIPHERLAB 1000 Handheld Barcode Scanner
3 Suggested Answers
  • 106 Answers
SOURCE: CIPHERLAB 1000 (serial ) Driver for WinXP
you dont`t have a driver for serial comm.open hyper terminal on com port where is the scaner.read a code and you wilkl see the numbers on the screen.If you want to work with some windows programs change that barcode for usb or ps/2 variant.
Posted on Feb 05, 2008
  • 52 Answers
SOURCE: Faut-il installer un driver avant
FIXYA ADMIN CHECK. Q APPROVED.
Posted on Jan 15, 2011
My CipherLab 8000 not scan the barcode.laser are open but can't scan.Could you please find out the solution.Thank you.
May be some one doing by mistake disable for all types of bar code ( not enabled ) or all sympologies.
Apr 25, 2016 | CIPHERLAB 8000 Series Handheld Mobile...
How do I insert comma into the scanned data of a cipherlab 8000?
If you using Forge, you could chose between comma or dot for decimal inputs in the latest versions of Forge.
Earlier just a dot were available.
May 30, 2014 | CIPHERLAB 8000 Series Handheld Mobile...
Cipherlab cl8200 timeout error? when exporting to hand held?
9f76079d-6fa0-4db9-9587-a2e27f8ce81a.jpg in the lookup section . select the following
that should solve the timeout problem
Sep 19, 2013 | CIPHERLAB 8000 Series Handheld Mobile...
I have a Cipherlab scanner 8001, when i connect it to a linux computer, it doesnt download it gives me a Time out error, but when i connect a Cipher scanner 711 to the same COM port it works. Please advice...
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
AUTO BAUD RATE
or
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
Jan 30, 2011 | CIPHERLAB 8000 Series Handheld Mobile...
Hello! I have a problem when programing the CipherLab 8001-C Application Program (AG8000N.exe). The download start (terminal bip) and after 3-4 sec show "Download Complete" but the terminal show the...
Cipherlab has technical support available - I'd recommend getting in touch with them. The Cipherlab global site is: http://www.cipherlab.com/default.asp - you can choose your region, then support or the contact link.
Oct 19, 2010 | CIPHERLAB 8000 Series Handheld Mobile...
I have got scanner 1000 but cannot scan the barcodes i have got. like TA010304, when i scanned it, other weird stuff would appear like 06^OX... anyone can help me? Thanks.
Hi there, you may check the settings of your scanner software, go to start>programs and check the scan software utility and from there check the settings of the scanning page/are so that it would see those barcodes you need.. or may lighten the scan settings as well.
Jul 07, 2009 | CIPHERLAB 1000 Handheld Barcode Scanner
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Jan 15, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
CIPHERLAB 1000 Handheld Barcode Scanner Logo
46 people viewed this question
Top CIPHERLAB Computers & Internet Experts
David Payne
David Payne
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
