Question about MSI Computers & Internet
Bios rom checksum error detecting floppy drive A error. system halt
  • MSI Master
  • 3,606 Answers
Hello download the manual here:
http://www.msi.com/service/download/
By entering the ms xxxx number, from the mainboard.
When you find your mainboard, click on download and select manual.
Download the manual, and you need adobe reader to read the content.
Your cmos battery on the mainboard, has lost it`s power and need to be renewed (the bios can`t remember It`s settings)
The battery is a CR 2032 watch type:
Bios rom checksum error detecting floppy drive A e - 1_23_2013_1_02_19_am.jpg
And fairly easy to change, with the shinny site upwards.
But you have to setup the bios, clock, date, boot settings when the job is done.
This is why, you need the manual.
Good luck
Posted on Jan 23, 2013
  • 74 Answers
SOURCE: BIOS CHECKSUM ERROR
Normally a bios checksum error is caused by a dead cmos battery. In a laptop that can be a pain - some are specialty batteries, some soldered directly to the motherboard, etc.
Start the laptop and enter the bois, there usually will be something to tell you what key to press, most of the time it is f2 or f10. Once in the bios set the date, time and boot order, then save and exit the bios. If it boots ok then try to determine what type of battery and it's location on the laptop to replace it.
If you let me know the make and model of laptop I will try to help determine that info and also where you can get the battery. That will more than likely be from eBay....
Hope this helps
Posted on May 02, 2009
ginko
  • 19396 Answers
SOURCE: Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Posted on Apr 03, 2008
BFixed
  • 104 Answers
SOURCE: Bios ROM checksum error
The rom you used to flash the bios may not have been the correct one for your mobo, or it did not complete the flash entirely. Try using the usb a drive to flash it again and/or revert back to an older version.
Posted on Aug 01, 2008
  • 254 Answers
SOURCE: BIOS ROM checksum error
have you a hard disk in the pc ?
somehow your hard disk has stopped booting (virus , bad hard disk boot sectors)
you may have to reinstall the OS
hope this helps
Posted on Jan 05, 2009
SOURCE: p4vmm2 v8.1 bios checksum error
Replace your CMOS Battery.
Posted on Mar 03, 2009
Computer wont boot up
first reconnect your keybord and mouse jack in computer then power up the compter then press del or F1 or F2 to nweter in bios setup then just press F10 and save settings .
Feb 07, 2009 | Dell Computers & Internet
BootBlock BIOS v1.0 BIOS ROM checksum error
Kevin, when you do get this going it is going to be a beast.Nice choices on the hardware. It appears that you are getting text in the bios menu and that is a real good sign. One bit of text you typed might be a clue." You typed Detecting floppy drive A media . . .
Drive A error. System halt" And you said that you had no Floppy. On the first screen were you see your time etc there will be something that says halt on all errors. Change that to halt on keyboard errors only. The wording may be different but you get the gist right?You don't want the bios seeing no floppy and halting on that.I hope this helps you and don't get discouraged. There is usually a simple answer.
Dec 13, 2008 | ASUS A8N-E Motherboard
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
6514MR-ES
Unplug mains from wall
remove lid
find CMOS reset jumper (usually 3 pins with a jumper/link on two of them near the button cell battery on the mainboard).
Move jumper to other position, then move jumper back again to original position.
fit lid and connect mains supply and switch on.
If you can go into the BIOS, set Defaults and set the date and time, Then try to boot.
If it has been of for a while and time is wrong when ou next boot it, replace the button cell battery on the mainboard.
Aug 07, 2008 | Intel Motherboard
Aug 01, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
Please help
Try pressing F2 / Del key during startup. That should bring the bios setup. Now Restore that defaults & install OS on your HDD. If you are not using Floppy drive, disable the onboard floppy controller from BIOS.
Jun 20, 2008 | ASUS P4SP-MX Motherboard
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
My ecs p4vmm2 cannot open to windows
you must have a faulty floppy disc unit, you need to press F2 or Del to get into the bios and check the time and date if they are wrong then the cmos battery needs changing.
Sep 11, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
926 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
