Change my password edimax router with out cd rom
  • 7,627 Answers
Perhaps this will help: http://www.edimax.us/
Posted on Jan 19, 2013
5 Suggested Answers
  • 556 Answers
SOURCE: i cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W / 6104P
Then
If I forget my password, what can I do?
I hope this helps.
Posted on Dec 06, 2007
nyilasrobert
  • 627 Answers
SOURCE: how to reset Edimax BR-6204Wg router? default wireless password?
push reset button at least 10 seconds
Posted on Jul 10, 2009
Turnip95
  • 72 Answers
SOURCE: password setup
You need to visit your routers homepage. Enter into your web broswer your IP. You then will be required to enter your sieral number on the back of your router and also default password which is normally:
Username: admin Password: password
Hope this helps, if you need more advice check your router manual.
Posted on Jul 28, 2009
SOURCE: Edimax BR-6424n router wireless works fine with
When you enter a WEP key, you must completely redo the new connection on the PC, remove the adapter and start all over again as in reinstall the driver, then do the connect to network, thing. BTW, you MUST save the setting in the router, and reboot the router, and then reboot PC, and then try to establish a connection. You should also use this tip, when you generate that BIG number WAP?WEP Key, copy/paste it to a notepad document, and save as wapkey. No after saving it in router and rebooting, when you come to the Field to enter the WAP/WEP key when logging onto the Router, you can simply copy & paste back from that notepad document you saved before. Now you should be able to login, remember to save network setting too. so you don't have to enter it each time you login.
Posted on Jun 25, 2010
Setup wizard
Usually the CD only contains info about the router and is not used to set up the router. What you need is the manual so you can login to the router. Once you get in, some routers will detect first time login and start a wizard which will help with the configuration. Others you have to navagate to the wizard and start it yourself.
Jan 19, 2014 | Edimax BR6204Wg Wireless Router
Can't connect to my edimax ar-7284wna router
theres a temporary solution... reset router and change the date on your computer to 1 febrauary 2010 and you will be able to login. you can set all your details and even if you change your date back to current it will not affect your settings however to log back into the router you need to set back your date to feb 2010..
Hope this works.
May 30, 2012 | Edimax Computers & Internet
Hello there, Just wanna know how will gonna change from default setting to a personalize username and password for our wireless router for us to have more secured access to our internet connection? Thank...
hello.. you will have to set this inside your router. to do so you can use some wizard in your router's CD or do it by hand using web configuration panel of the router.
the manual setting is not hard to be done.
i guess your router is all default settings, so to access the web interface, you have to open your web browser (Internet Explorer for example) and enter 192.168.2.1 in the address bar then hit enter. you should be prompt for user/password, and the default one are user: admin password: 1234
this will let you change settings. you will find the WIFI settings in the "General Setup" section.
i am attaching link to the user manual, if you like to dig in to the settings deeper:
http://www.edimax.com/images/Image/manual/Wireless/BR-6225n/BR-6225N_Manual.zip
Sep 18, 2011 | Edimax BR-6226n nLite Wireless Broadband...
How to change my password in wifi?
You can configure the router by running the Setup Wizard in the
CD-ROM provided in the package. The wizard provides quick setup
for the Internet connection, SSID, wireless security, firmware
upgrade and changing router's password. When you start the
Setup Wizard, you will get the following Welcome screen. Please
choose the language to start with and follow the easy steps in the
Wizard.
Manual Below:
http://www.edimax.co.uk/images/Image/manual/Wireless/BR-6226n/BR-622xN_Manual.pdf
May 10, 2011 | Edimax BR-6226n nLite Wireless Broadband...
EDIMAX BR-6428nS
Hi emmanuel,
I also have the same Router, what would you be needing assistance with?
if you are asking how to get in the Edimax Settings you just need to enter 192.168.2.1 on your internet explorer address bar then press enter, thiswill promt you to enter a user name and password
User name - admin
Password - 1234
unless you changed the user name and password then it shall be different.
I really am sorry but I do not have a clue what to tell you since I already asked for clarification the day before but I have not recieved any information about you concern.
Have a nice day.
Apr 06, 2011 | Edimax 4 Port Wireless AP Broadband Router...
Edimax br6204wg wan led doesn't light up and there is no internet connection
Hi yaminmagdi,
I believe that you are trying to get connected wireless using your Edimax Router, we may need to check some settings in your Edimax regarding the wan light not lit up and could be a possible reason why there is no internet connection.
1. First we will need to find an Ethernet cable for us to be able to connect your Laptop directly to your Edimax Router for us to be able to check and change any settings needed to enable your Edimax wireless connection. also make sure that the Ethernet cable is connected to the Ethernet ports behind the Router not the WAN port then the other end goes directly to your Router.
2. Once connected directly to your router from the Laptop open IE or any Browsers on your Laptop, in the Address bar type in 192.168.2.1 then press Enter this will prompt for a user name and password, User Name will be ' admin ' and the password should be 1234 unless you changed it.
3. Inside the Edimax setting page click on the Tab that says Wireless, check and see if the wireless is enabled if not then enable it or turn it on, after enabling / turning the Route ON save the settings by clicking on Apply or Save then it will prompt that the Router is restarting it will be 30 seconds to apply once the 30 seconds is up that should be done check your Edimax if the WAN light is already lit up, then you can try an connect Wireless from your Laptop.
I hope this helps.
Have a nice day.
Apr 03, 2011 | Computers & Internet
Trying to set up my edimax modem but have lost the cd. the admin/1234 username/password combination does not work
First off what model is it?
Second off if you changed the password or bought it off someone else there is a small hole (like the size of a ballpoint tip on the back which allows you to reset the entire box to delivery defaults. Push it in with an unbent paperclip or similar in the hole. The admin 1234 should work then.
Mar 25, 2011 | Edimax Computers & Internet
How to change dns
I am not familiar with Edimax, personally...however, you can find out a lot of information by understanding a bit about the computer attached to it.
Assumptions:
It's a home network
You are running a Windows machine
Your windows machine is connected to the Edimax router
Your Edimax router is also your default gateway
drop to a command prompt (start, run, CMD, enter)
Type ipconfig and hit enter
This will get you your IP address of your local machine as well as the subnet mask and the default gateway.
Once you have the default gateway, you can connect to it via Internet Explorer. You will need to set it up as http://192.168.1.1 (where the IP address is your default gateway)
At that point, you will need your router password
Once you get in, you can then poke through your settings and manually change the ones you need.
Hope this helps.
Nov 11, 2008 | Edimax Computers & Internet
I cant access my router(EDIMAX BROADBAND ROUTER)
Then
I hope this helps.
Dec 02, 2007 | Edimax BR-6104KP Router (BR6104KP)
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
