Question about Miele Novotronic W1918A Front Load Washer
Miele novotronic W145 washing machine spullen light flashes
  • Miele Master
  • 17,129 Answers
Problem answered earlier.
Posted on Jan 19, 2013
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Posted on Jan 05, 2008
  • 70 Answers
SOURCE: Miele novotronic w820
i havent changed one on this model but there useally much the same and qiute easy to do first take the back off the machine
at the lower half of the rear of the drum there is two prongs sticking out with wires on spade connectors a third earth wire in the centre remove these 3 wires they should just pull off but sometimes held on by nuts you will have to check yours then with the machine emty of water unbolt this is the element assembly is the reverse
Posted on Jul 26, 2008
Gallois
SOURCE: Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Posted on Sep 09, 2009
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele novotronic w145 s spullen light flashes
Possible that this error can be due to the INLET or the DRAIN being clogged or is not functioning. Remove and clean the filter to both the inlet and drain.
Jan 19, 2013 | Miele Washing Machines
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Flashing rinse light miele novotronic w828
Broken electronic as a result of worn shock absorbers. See www.youfixit.eu
Aug 27, 2012 | Miele Novotronic Premier 500 Front Load...
Main wash and rinse lights both flashing together and machine stopped
main wash and rinse lights both flashing together and machine stopped
Feb 09, 2011 | Miele Novotronic Premier 500 Front Load...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W1918A Front Load Washer Logo
284 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
