Question about Canon Pixma iP2700 InkJet Photo Printer
Ip2770 black ink doesn't apperar on paper although there is no nitification of cartidge damage
    Problem Solver:
  • 8 Answers
You most proberbly have a clogged black catridge. try cleaning from the printer's maintenace tab. if it doesnt improve after a few cleans, do a deep clean. if it still doesnt work and you dnt feel like buying a new catridge yet, steam the nozzle of the catridge. these steps almost always do it, if not, just get a new catridge and voila!
Posted on Jan 20, 2013
old marine
  • 1992 Answers
SOURCE: Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Posted on Oct 16, 2008
MUKHTAR
  • 2017 Answers
SOURCE: mp145..color & black ink button keep blinking...help...
kindly replce the catridges and reinstall the printer driver.
Posted on Jan 21, 2010
  • 328 Answers
SOURCE: The black print won't print, but colour does,
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
Posted on May 27, 2011
F Victor man
  • 817 Answers
SOURCE: I'm getting an error V150
Error U150 refers to a cartridge not being recognised. This is due to the refilled cartridge. The machine knows that the cartridge has already been used and is expecting a new one. Some people say that if you hold down the stop key for 3 seconds when powering up it will remove the cartridge check. I have never tried it personally.
Posted on Jul 10, 2011
  • 8 Answers
SOURCE: I've changed the ink cartidges
This hapens when refilled cartridges are installed in the printer. To rectify the problem, look for the 'Resume button' normally black with a red circle around an arrow head pointing towards you. With the printer powered on, press and hold this button down for about 10 seconds. The error code will usually clear and the printer will print but the orange lights will still flash.
Posted on Sep 11, 2011
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Creased paper
Check the Fuser (rubber roller usualyl a pain to get too with out tools) for caked toner. You will more than likely have to get the printer serviced if it was badly contaminated with toner.
Oct 03, 2012 | Samsung Office Equipment & Supplies
How to convert my canon pixma iP2770 to continuos ink?
goodday!
you can convert your printer if your printer cartidge has 4 colors, magenta, cayan, yellow and black.
Mar 21, 2011 | Computers & Internet
IP2770 EROR B200
If your all cartidge is not fully loaded on ink than showing the error.
Dec 09, 2010 | Canon Pixma iP2700 InkJet Photo Printer
Problems with Lexmark X2550. I have refiled for the first time a lexmark 28 cartidge. Now I have paper jam all the time, I cannot print and I don`t know what to do. I blame the cartidge, because before...
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 03, 2009 | Lexmark X2550 All-In-One Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
Printer is not printing black
Remove cartridge and remove the mains from the wall.
Try cleaning the contacts with a cloth dampened WITH WATER, wipe it up with another cloth and let dry.
If your old cartridge is not working again, try with a new one, generally is the cartridge which may become damaged, not the printer... hope !
Dec 31, 2007 | Lexmark X1150 All-In-One InkJet Printer
Canon Pixma iP2700 InkJet Photo Printer Logo
200 people viewed this question
old marine
old marine
