Question about Dometic Refrigerators
Have a Dometic Chestcold F/F Mod.F400EGP not getting cold or freezing
Not getting cold or icing up properly
  • 531 Answers
SOURCE: RV ice box freezes everything
if it have a timer board change it
Posted on Mar 31, 2009
MNTECH
  • 1543 Answers
SOURCE: HELP ME
Remove back wall from inside freezer and melt all frost with a hair blower. The most likely cause of the frost build up is a burnt out defost heater, second most likely cause is the defrost control. Can't give you part numbers because you don't list a model number or even a brand. Melting the frost and not fixing the underlying problem will get your refrig working for a week or so until the frost builds up again.
Posted on Jul 03, 2009
erpaalai
  • 999 Answers
SOURCE: my rv fridge will build up ice and freeze food too cold
The thermister for the temp control is a likely culprit. Eric
Posted on Jul 07, 2009
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
Posted on Aug 24, 2009
Jennuwine
  • 23 Answers
SOURCE: Freezer not freezing frig not
Could be a couple of different things,
Defrost Heater,
Defrost Thermostat
Damper Assy
Here is a link to try for the items and breakdown
http://www.repairclinic.com/Appliance-Parts?s=t-PSS23LGSA+WW-%3d%3dc24
Sorry we could not help with the actual purchase of the replacement parts, Good Luck"
http://stores.ebay.com/Discount-Appliance-Parts
Posted on Sep 16, 2010
I have dometic AC 630515.331. I was having a problem with it cooling properly. A service guy checked it out and said the cold control wasnt working properly. Im trying to replace it but I dont see a cold...
When you say, wasn't cooling properly, could you give more details such as, cooling would not shut off, cooling would cut out before trailer was cool, fins/coils were frosting or freezing up. Compressor was kicking out and in too much or any other symptom you notice. All will help with proper diagnosis.
Apr 02, 2013 | Dometic Rooftop RV Air Conditioner
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
Dometic model ndr1292.my water tube for ice maker is falling apart.how do i replace it?
it depends on whether you can get to the back of refrig from the out side. if you are lucky enough to have 2 access panels behind the refrig you are able to do it without removing refrig. i just replaced mine. i bought an ice maker kit at home depot and just used the hose and fittings cutting the hose to size. if you are in cold weather i would recommend using the heater wires that are wrapped arount the old tube. they keep the water from freezing. hope this helps.
Jul 15, 2009 | Dometic NDR 1292 Refrigerator
Mar 31, 2009 | Dometic Refrigerators
Refrigerators Logo
26 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
